Timing belt replacement
Old May 28, 2011 | 01:37 PM
  #31
BlackknighT's Avatar
If the timing belt aint broke-I say fix it anyway! Preventative maintenence is good-or just bring a roll of duct tape... Or get the chain upgrade that I got.
(Disclaimer-sorry bout the post-with so much crap going on right now-I had to make myself laugh)
Old Dec 3, 2014 | 08:04 PM
  #32
usmctrust94's Avatar
timing chain
Ok qui k question i have 2011 chevy hhr drove is to walmart killed it went inside came back out wouldnt crank , took it to a shop
shop says timing chain is broke an dthat they need to take the heads off to replace it. Is this true if so thats fine. Or can it be done with out taking the heads off
Old Dec 3, 2014 | 08:22 PM
  #33
pg318's Avatar
They'll want to take the (one) head off to check the valves and likely replace the damaged ones... Did it make much noise when trying to restart it?
  #34
Taking the head off is to inspect for for other damage like valves and piston interference. It should only be a little more money, if there is no more damage.
You might want a second opinion anyway.
Old Dec 4, 2014 | 09:58 AM
  #35
Ron S's Avatar
How many miles are on it an 11 may still be under drivetrain warrenty
LEN
Jul 8, 2015 01:24 PM
Bustluvr
2.4L Performance Tech
17
Apr 16, 2015 06:08 PM
SteveMaine
Maintenance and Upkeep
Sep 21, 2013 12:39 PM
rywegh
Jul 4, 2012 02:54 PM
wagoneer
Apr 9, 2009 11:44 PM
