Tire pressure sensors and key fobs not working.
Old Mar 5, 2024 | 10:40 AM
Jim's 2009's Avatar
Originally Posted by Oldblue
Could be a blown fuse, a loose relay, a loose ground wire. Try tightening the under hood fuse box bolts, there are 4 of them 7 mm heads, then push all the fuses and relays firmly into position, same for the fuse panel on the passenger side of the console.
The bolts were loose but it didn't help.
Old Mar 5, 2024 | 10:44 AM
Time to pull down the headliner and check the wiring connection at the RCDLR.
Old Mar 10, 2024 | 03:17 PM
PulpFriction's Avatar
You talking about removing it or just tugging down on it a bit? I'd be worried about permanently bending it, but I understand complete removal is a serious PITA.
Old Mar 11, 2024 | 09:41 AM
Jim's 2009's Avatar
I found there was an issue with the RCDLR in the 2008 HHR a TSB had been issued. Stopped at the dealers and they said they could try to reprogram it with no guarantees $150 I said no. Not going to spend that on a car that I will drive to the junk yard by the end of august.
Old Mar 11, 2024 | 11:49 AM
That TSB applies to 2008 only. That was the first year of mandatory TPMS and the programming was faulty only for the TPMS door locks not affected. I would have mentioned it if yours was a 2008.
I would replace fuse #23 on the BCM (the fuse box on the passenger side foot well). Whatever caused a fuse to blow needs to be fixed, they don't wear out. Your RCDLR is not getting power for some reason. If you remembered what fuse blew before it would help.
Why would you drive it to the junkyard?
Old Mar 17, 2024 | 10:38 AM
Jim's 2009's Avatar
It is a 2008.
Old Mar 17, 2024 | 11:08 AM
2008, 2009, doesn’t matter. Based on post #1 that you lost power to the mirror and RCDLR, you need to check that receiver for power. As in , pulling the headliner.
Or just ignore any suggestions and go get it reprogrammed.
Old Mar 17, 2024 | 02:39 PM
Well now let's just back up a minute. If I understand correctly, the fuse (for the rear view mirror) blew during the Windshield installation. The fuse was replaced and the mirror works now. The only problem left is the TPMS, which is the subject of the 2008 only RCDLR problem. Is this all correct, Jim? Or do the fobs not work at all? Have you replaced the fob batteries yet?
Old Mar 18, 2024 | 02:51 PM
Jim's 2009's Avatar
Fobs do not work batteries good checked the solder connections.
Old Mar 18, 2024 | 03:55 PM
And the fob contact points are clean?
