Traction control light; hard shift
Old Jan 31, 2024 | 01:41 PM
  #61
PulpFriction's Avatar
Originally Posted by HB2
My '06 2.4L does this also. It throws a "cylinder 4 misfire" code, and with a diagnostic read, #4 is misfiring. I replaced all four plugs; all four coils; intake manifold gaskets, but it still throws the check engine light and cylinder 4 misfire code. I see below, camshaft sensors may be my next move.
Don't do that yet. And I'm pretty sure you're talking about the VVT solenoid valves, which sense nothing. Pic at comment 53 above. The cam position sensors are on front and back of the head on the driver side. But none of those are like to be related to a single cylinder misfire.
What exact plugs and coils did you use in replacement? The p/n's.
Did you happen to do a compression check when the plugs were out?
How many miles on the car? Any prior or other history of engine problems?
Strongly recommend you get hooked up to a capable scan tool, one that will read all codes, not just P codes, and post the numbers here. All of them, even if you think they're unrelated.
Old Jan 31, 2024 | 04:05 PM
  #62
Is P0304 the only code? Anything you assume is not relevant.
Have you done a compression and leakdown test?
Old Jan 31, 2024 | 04:35 PM
  #63
If it's not a plug or a coil, the other possible culprits are an injector or gunk in the fuel rail, or a mechanical problem (diagnosed with the compression or leak down test that donbrew mentioned.
Old Feb 2, 2024 | 04:15 AM
  #64
HB2's Avatar
HB2
Those are the numbers on the scanner while engine is running.
Old Feb 2, 2024 | 04:17 AM
  #65
HB2's Avatar
HB2
No other codes and no compression test or fuel rail cleaning, yet.
miles solo
May 23, 2022 06:41 AM
50%buffalo
Jun 14, 2014 06:16 PM
Mrb
May 30, 2014 09:57 PM
FMHHR
Apr 28, 2014 09:30 PM
