Transmission Mount Needs replaced
https://cimg2.ibsrv.net/gimg/www.che...4777bfb8e0.jpgSafe to assume this shouldn't look like this?
https://cimg9.ibsrv.net/gimg/www.che...e4b2cd7241.jpg Should I consider replacing any other mounts while I am at it? Vehicle has 72,000 miles. 2010 HHR Panel LS |
Read this:
https://www.chevyhhr.net/forums/driv...-mounts-36963/ While you at it get their engine mount also. |
There are 2 trans mounts and a motor mount, and a bracket between the trans and motor that I had crack, it was cheap <$20.
I’d say it’s shot! May I suggest changing all three mounts as a set. I’ve read that different companies have different compounds of rubber and aren’t completely compatible!
Order one front and one rear transmission mount RockAuto And one upper engine mount RockAuto From the same company. I myself prefer AC Delco products, however I posted the RockAuto site as an example. |
[QUOTE=Oldblue;835108]I’d say it’s shot! May I suggest changing all three mounts as a set. I’ve read that different companies have different compounds of rubber and aren’t completely compatible!
Thanks. I just placed the order for all three. |
Glad to help, I figure if I learned something could be a problem, share that information, save someone else the trouble.
Are y’all changing these yourself? Torque valves are in the How to section |
| All times are GMT -5. The time now is 03:33 AM. |
