transmission mounts
Old Jul 14, 2015 | 06:27 PM
webpirate's Avatar
transmission mounts
I replaced the rear transmission mount yesterday everything was fine.. Replaced front transmont today and engine shakes bad when In reverse or when AC is turned on...
Any ideas?
I am thinking anchor mount rubber is too hard...might have to get OEM..
Old Jul 14, 2015 | 06:43 PM
Double check the torque on all fasteners, it could also be the engine mount is shot!
Old Jul 14, 2015 | 07:16 PM
webpirate's Avatar
ok
OK thanks I will check torque and engine mounts... Are the anchor/dea mounts bad quality?
Old Jul 14, 2015 | 08:11 PM
Depends on what you bought and where, you state not OEM
Old Jul 14, 2015 | 08:17 PM
webpirate's Avatar
aftermarket
I bought dea a3081 from amazon. Rubber seems really stiff
Old Jul 15, 2015 | 05:35 AM
Is it rubber or polyurethane?
Old Jul 15, 2015 | 06:11 AM
For the record; there is only one motor mount, it's the one on the top passenger side. It is what normally goes bad.
There is also a solid bracket tat connects the trans to the motor, that is sort of a trans mount.
Are you sure it's the mounts causing the vibration, not the trans?
Old Jul 15, 2015 | 08:40 AM
webpirate's Avatar
trans mount...
I took out the dea a3081 mount and put back the original OEM mount and the shaking has stopped....
The dea mount is rubber but a lot stiffer than the drive tech mount that I replaced on the rear trans moubt..
I went to another place in the city that sells anchor mounts and its identical to the dea rubber..
So I either find a drive tech or an OEM
The drive tech mount I swapped out on the rear mount was identical in rubber composition and flexibility as the OEM minus the cracks that the old on had....when I changed that it removed about 95% of the shaking that was there before so in figured I would change the front one to remove the other 5%.... Well it all seemed good when I put the car into drive... Then when I put it into reverse it was really shaky.
Now that I put the old front mount back in its back to 95% non shaky....
VinceP
May 21, 2012 06:35 PM
Doom
12
Mar 7, 2012 06:13 PM
hhrfreek
Drivetrain (Excluding Engine)
7
Aug 13, 2011 07:12 AM
