Trys to start when I hook up battery...
Old Oct 24, 2022 | 08:01 AM
If you want more info about the OP’s car and problem, check out their other threads/posts. There are many. Tells about engine and trans swaps. Starter problems (seems they had starter issues before). There’s even a thread about all the wheels being “locked up”.
Old Oct 24, 2022 | 10:18 PM
greg8453's Avatar
Hook it all up except the starter and do some testing.
Old Oct 27, 2022 | 10:59 AM
FirstGenHHR06's Avatar
How do I do that?
Old Oct 27, 2022 | 12:28 PM
greg8453's Avatar
Originally Posted by FirstGenHHR06
How do I do that?
Take the large cable off at the stud on the starter. Make sure the cable end doesn't touch anything after hooking up the battery.
Old Oct 27, 2022 | 02:06 PM
Danger! Danger! Will Robinson!!!
Old Oct 27, 2022 | 07:45 PM
I meant testing...
Old Oct 27, 2022 | 09:59 PM
greg8453's Avatar
Test just like you would with the starter hooked up. Key on do you hear any clicking? Check ignition switch? etc
Old Oct 28, 2022 | 06:21 AM
If you're going to disconnect the main power to the starter, it would be much easier, and a whole lot safer, to disconnect it from the lug on the side of the fuse block. Disconnect the negative battery first, of course.
Old Oct 28, 2022 | 08:12 PM
Ok another one for you guys, how do I get the key out of the ignition?
Old Oct 28, 2022 | 08:50 PM
Read your Owner Manual, directions with drawings are in it. See the link in my sig.
It does that from a dead/disconnected battery.
