turbo info
yes i know this but i was just throwing it out there because of the 2.2
That is for Cavaliers and Sunfires not HHRs. The tubing will not match. You are better off waiting or your going to end up with one of the biggest headaches ever trying to fit it to a HHR.
i still dont have an HHR but im doing research first so i know which engine option to get i hope someone makes a turbo for the 2.4 because thats the engine im leaning towrds @ 177hp pop a turbo kit on it and sqeeze out about another 100hp and ill be happy at 277HP!!!
They will probably make a kit for the HHR then if they already have everything worked out with the 2.2 Ecotec. I need a kit for the 2.4.
TurboTechRacing
2.0L Performance Tech
0
Oct 28, 2009 09:03 PM
You know what I meant SoCal.
What brand did you go with?
