Weird Exhaust Sound
Old Jun 2, 2020 | 06:48 AM
SwaintaN's Avatar
As soon as i can find someone to do a stainless steel weld. Im hoping that is all it is.
Old Jun 2, 2020 | 08:31 AM
Is that the same muffler guy that can't weld stainless? MIG or TIG in most shops I've seen.
Old Jun 2, 2020 | 08:43 AM
SwaintaN's Avatar
Ill be honest I don't know anything about welding. It was a private individual I had do it first time.
Old Jun 2, 2020 | 04:37 PM
A oxy-acetylene weld would not do it but just about anyone that calls them self a welder and has a tank of gas and a machine can weld stainless.
Old Jun 2, 2020 | 06:41 PM
I prefer to TIG weld stainless but it can be gas welded.
Old Jun 3, 2020 | 07:17 AM
  #26
SwaintaN's Avatar
So I should ask if they know how to TIG weld? to make sure its done better?
Old Jun 3, 2020 | 07:36 AM
  #27
Or Mig, get them to fix the holes
Old Jun 3, 2020 | 07:54 AM
  #28
If the weld is solid but has a few leaks you can put a band clamp on it...
Old Jun 3, 2020 | 08:42 AM
  #29
Cat Man HHR's Avatar
It depends on where the leak is.
Band clamps only work on straight pieces of pipe, not bends.
Stainless is a word used loosely.
High grade stainless needs to be welded properly. Real stainless won't allow a magnet to stick to it because it is not ferrous.
Exhaust systems are a lower quality stainless that can be welded with mig/tig or oxi/acetylene with the proper rod.
Here's something to read:
https://help.summitracing.com/app/an...nless-steel%3F
Old Jun 3, 2020 | 09:07 AM
  #30
Did you look at the photo of where his weld is?
