weird observation
Old Dec 1, 2018 | 01:13 PM
Cliffs51's Avatar
weird observation
I own 2 HHR 2.4's. A road I travel on a lot has a sweeping right hand curve. I usually drive with the engine temperature display on. On both of my HHR's if I take that curve fairly fast the temperature display drops by 2 degrees after I go thru the curve. ??????
Old Dec 1, 2018 | 04:15 PM
In both directions? A wind shift thru the grille? I’d just hang on and enjoy the ride a fluctuation of a few degrees won’t hurt.
Old Dec 1, 2018 | 04:18 PM
Cliffs51's Avatar
Yeah im not worried about it I just thought it was strange. Other cars may do the same the hhr is the first car ive had with the digital readout
Old Dec 1, 2018 | 04:25 PM
I had a 72 Dodge Dart, it would pop the windshield out if it got grip shifting from 2nd to 3rd. Now that I worried about. But the temp shift , in the HHR it could be a number of things.
Old Dec 1, 2018 | 05:56 PM
2 degrees is nothing - ya gotta stop overthinking things Cliff. And stop staring at that temperature digital readout.
Old Dec 1, 2018 | 06:13 PM
Plus. The temp readings go in 2 degree increments(ex.185, 187 189) so not that big of a deal.
Only odd thing about those 2 degree changes is it will do a 1 degree change from 189-190. Then go 192,194 etc.
Old Dec 1, 2018 | 07:02 PM
You are not taking that turn anywhere near fast enough if you have time to look at the temp gauge...
Old Dec 1, 2018 | 08:54 PM
Silverfox's Avatar
Are you backing off on the throttle around the turn ??
Old Dec 2, 2018 | 06:40 PM
Right on.
Ok, how about on the return trip, which makes a left turn out of that sweeper?
Old Dec 2, 2018 | 07:43 PM
Cliffs51's Avatar
Lol. Im sure other cars probably do similar things they just dont have a digital temp readout.
