What the...?
What the...?
I took my car to wal-mart to have the oil changed and they told me they couldn't do it yet because they don't have a book for 06's. Has anyone else run into this problem? As soon as I get some time i will have to look at it myself. On my last car the owners manual told how to change it, no such luck here.
I didn't even know Walmart does oil changes. I think I would go to a quick change place before I went to Walmart. I go to my dealership because they only charge me $10. snksknr94 you left out the part about putting oil back into your engine.
DAMMIT!! That was the first how to I've ever written and I screwed it up. Thanks Howdy!
Forgetting to replace the oil has unfortunately happened too often!
The worst I've done was many, many years ago. After draining the oil, changing the filter and adding the new oil, I looked to check for leaks. Found a BIG one, as evidenced by the huge oil puddle under the car!! DOH... gotta put the pan drain plug back in before filling!!
Hell, I have had this problem with a 1992 Mercury Capri at a local 20-minute oil/lube establishment! I get it done at Wal-Mart instead.
I've heard that sometimes Wal Mart forgets the part about putting oil back in!
