What Brand of Gas
What Brand of Gas
I was told by the head mechanic at the dealership where I bought my HHR that the manufacturer actually recommends that you use Shell Gasoline. Is there anyone else that has heard this information or use something else instead?
They do recommend that you buy it at the same dealer every time. My check engine light would come on last summer if I didn't. So now I try to do that unless I'm traveling. Then I buy whatever is cheapest where I exit the interstate.
Used to use ARCO because it was closest to home. Then they closed that station 'cause it was old, old. Probably some "Enviromental Problem"! Now it's QT, or Union, at a local Circle K. They're the cheapest.
