What is the light/How do I turn it off
Old May 27, 2012 | 10:25 PM
JMichael's Avatar
2008 2LT
Head lights on (auto mode), a ~ 1/4 dia. light is on near the controls for the
sunroof. The light is distracting and I want it OFF. It must be in the manual but I can not find the answer.
Thanks
JMichael
2008 2LT
Old May 27, 2012 | 10:28 PM
That (if I understand your post correctly) is the LED that is aimed at the window switches for nite visibility.
I like it myself..
Old May 27, 2012 | 10:52 PM
And you cannot turn it off. You can however, take the cover off and disconnect it, or put in a little switch on that cover, if it bothers you that much.
Old May 27, 2012 | 11:11 PM
lady3bglover's Avatar
its the GM mood light...grab it with a pair of needle nose pliers and break it..if it bothers you...But you can unplug it.....
Old Jun 1, 2012 | 10:18 AM
wuds's Avatar
Tape?
Old Jun 1, 2012 | 10:24 AM
Originally Posted by wuds
Tape?
You should know that you only use tape to cover the "Check Engine Light" when it won't go off.
Old Jun 1, 2012 | 11:12 AM
Breadfan's Avatar
Yeah, I checked, my engine is still there.
Old Jun 1, 2012 | 11:40 AM
Premiere07's Avatar
Old Jun 1, 2012 | 12:35 PM
whitelightnin's Avatar
black tape is good for ABS and airbag lights too!
Old Jun 1, 2012 | 08:00 PM
good for the seatbelt light, but then mine goes out on it's own after 5 minutes or so.
