What are the lights on heater control knobs?
Old Sep 18, 2006 | 05:08 PM
JimZ_HHR's Avatar
Originally Posted by nfboy
Page 3-21
Rear Window Defogger
The rear window defogger uses a warming grid to
remove fog from the rear window.
The rear window defogger will only work when the
ignition is in RUN.
<(Rear): Press the button to turn the rear window
defogger on or off. Be sure to clear as much snow from
the rear window as possible. An indicator light below
the symbol will come on to let you know that the
rear window defogger is activated.
The rear window defogger will turn off approximately
15 minutes after the button is pressed. If turned on
again, the defogger will only run for approximately
seven minutes before turning off. If turned on again, the
defogger will only run for approximately seven minutes
before turning off. If vehicle speed is greater than 50 mph
(80 km/h) and the rear defogger is active, it will remain on
as long as the speed is greater than 50 mph (80 km/h).
The defogger can also be turned off by pressing the
button again or by turning off the engine.
Notice: Do not use anything sharp on the inside of
the rear window. If you do, you could cut or damage
the warming grid, and the repairs would not be
covered by your warranty. Do not attach a temporary
vehicle license, tape, a decal or anything similar to
the defogger grid.
3-21
Thanks for that... I guess i only looked in the INDEX.... go figure
Old Sep 19, 2006 | 06:30 AM
Black Beauty's Avatar
Theres a sticky post where you can download a owners manual, seems like if it`s on the computer, people would read it... ( oops, hope I`m not in trouble)
I went on a search to let you know where to find it, not successful, maybe Courthouse Deb will jump in here... She`s pretty good at finding stuff. I`m not ( except trouble ).
Old Sep 19, 2006 | 07:46 AM
dudleyfamily's Avatar
I am glad someone else started this. I also have some questions about the air. I live here in Houston and have the air on all the time. I noticed the button (light)on the temp control knob. There does not seem to be a difference if the light is on or off. I know it says it is to turn the air off and on. Oh well car works great 32 mpg @ 80 miles per hour who can complain?
Old Sep 19, 2006 | 10:30 AM
mudbilly's Avatar
if you have the "internal circulation" (instead of the "mix with external air") button pressed (the right button) the AC is always on and in the maximum cooling mode.........and for what ever reason..........the AC light is not lit
Old Sep 19, 2006 | 12:00 PM
James06's Avatar
Originally Posted by Harpozep
Yeah, this car keeps surprising me. I read here about the intermittent wipers going into full mode when going over 45 MPH. Sure enough, it is true. It is likely in the owners manual, but I must have glossed over it.
Mine doesn't do this. I'm glad it doesn't, since I'm almost always over 45 mph, but now I wonder if I should get it checked.
Old Sep 19, 2006 | 02:08 PM
SindyDix's Avatar
So am I!
Here is the Sticky Thread link for the Owners ManualI hope this helps!
Old Sep 19, 2006 | 02:28 PM
Snoopy's Avatar
Just curious.....
You mean to say, that you didn't get an owners manual with the purchase of your vehicle?
Old Sep 19, 2006 | 02:46 PM
mudbilly's Avatar
mine doesn't do it either.........and i would rather it stay this way.....not even going to mention it to the shop
Old Sep 19, 2006 | 03:19 PM
mizzouHHR's Avatar
From my experience the wipers only go into full motion at 45 MPH if your delay is on the fastest setting, otherwise the delay stays the same regardless of speed.
Old Sep 19, 2006 | 03:30 PM
James06's Avatar
OK, that makes sense. It wouldn't bother me to go from the fastest intermittent setting to always on. If I'm up to the fastest setting, I'd just as soon they be on. Thanks for the info.
