What is the rear end knocking noise that ALL my HHR’s have had ?
Old Nov 6, 2020 | 01:27 AM
2manyvans's Avatar
Originally Posted by Silverfox
4 different HHR's with Broken Spring ??
Them's Pretty Big Odds.........
Somewhere way back I read a post on this site that the HHR owner had a noise in the Rear that he just could not find.
In desperation when he was replacing the rear shocks he noticed that the bolts were threaded over most of the length,
He just took a chance and found some new tempered bolts with a much shorter thread length and put them in.
That was the end of the noise.
He does not indicate if it is on one side or not.
Silverfox
That is exactly how my '08 panel was at 20,000 miles and the bolts were tight. No shoulder, just all threads......john
Old Aug 8, 2022 | 06:27 AM
Bradfo's Avatar
Have the same problem
Originally Posted by Davyo
Over the years I’ve owned 4 Panels and they have all suffered from the same exact knocking noise that comes from the underneath rear end, my current Panel only has 51,000 miles
It only happens when going over speed bumps, the noise doesn’t happen when accelerating or normal driving.
I’ve have just always ignored it figuring it was a defect that’s common with all HHR’s since all of mine have had the exact same noise.
It almost sounds like loose shocks but that’s just a wild guess.
Any input would be greatly appreciated.
Thanks, Davyo
I kept on hearing this knocking noise when driving and hitting small bumps in the road. I could tell the noise was coming from the right rear passenger side (somewhere around the wheel).
Upon closer Inspection I noticed that the Spring Coil had broken at the bottom. Photo attached
Old Aug 8, 2022 | 12:12 PM
PulpFriction's Avatar
Over the years I’ve owned 4 Panels and they have all suffered from the same exact knocking noise that comes from the underneath rear end…
Were they all used for work and you haul heavy stuff?
Old Aug 8, 2022 | 04:00 PM
Rear springs are easy to replace, do it in pairs , remove those brake hose bolts and bottom shock bolts, don’t remove the wheels, they help with gravity to get the springs out and the new ones in. Use jack stands for safety!
Old Aug 9, 2022 | 01:46 AM
Davyo's Avatar
As far as I know none of the panels I’ve owned we’re used for commercial use or hauling heavy stuff.
It’s just really funny and frustrating that all 4 of my panels have all had the same knocking noise including my current 09 panel.
Davyo
Old Aug 9, 2022 | 06:25 AM
Is it a broken spring? Or loose shock mount bolts?
Old Aug 9, 2022 | 07:16 AM
Read post #9 again.
Mine had that thump noise too. After looking at the usual stuff, (springs, shocks) I found that loose, poorly designed rear bumper cover. Got it tightened up with some foam inserts and eliminated much of that noise.
Old Aug 9, 2022 | 06:51 PM
Read post #9 again.
And by the way never let anyone ever step on that rear bumper. “NOT A STEP.” You would think the designers would have anticipated someone stepping on it but, no.
08LaRam
14
Dec 16, 2016 05:32 PM
Ben Calder
Feb 25, 2012 09:01 PM
SSROADSTER
0
Feb 13, 2011 09:58 AM
Scrivs
Jun 9, 2010 01:26 PM
ssmail8835
Jul 27, 2006 05:36 PM
