What is the stupidest design error?
For those of you that think the air filter is hard to replace...... the one in my HHR is simple compared to my Motorcycle. On the Goldwing its a 2 hour job.
As for design flaws, I agree headlight bulb access is a pain but having to remove the front bumper cover to replace the headlight assembly has to be the worst thought out idea.....with one exception.
Who thought up using a rubber edge seal on the thermostat..........after having to replace 4 of them now it gets my vote for the worst design flaw.
I know this sounds monumentally stupid, and it does when you really sit and think about it, but popping the bumper off once you've done it a time or two....makes bulb changing a snap. It just sounds so much worse and so much more involved than it really is.
Got another one after trying to check the water level in the radiator overflow bottle today .
Flashlight in hand head down close to the fender and radiator support bar and pray you can see pink antifreeze .
This should just be simply a pop the hood and look at a bottle task.
???Advantage to having a twisted spine??? I doubt it.....
@ 843de....
Uh oh! There's gonna be a rumble, I can just feel it.
