Where do I get another key for my 2006 HHR?
Is it true that the dealer is the only place to get one? How hard is it to reprogram another key. Are the blanks available on line? How much money does a new key cost?
(Thanks, Tom)
Look closely at your key(s). Just where the key comes out of the plastic there should be a + on the ket itself. Mine is an 07 ls and it is passlocked.
Far as I know all the HHR's use chiped keys. As far as reprograming the key, check your owners manual. As far as the fob, either the dealer, or some locksmiths will have the equipment to do it for you, but I'm not sure how much you would save. The equipment is not inexpensive. Worth checking out, though.
