Will this combo of wheels and tires fit?
Sorry to bother you guys, but I can't get a straight answer from my local tire place. I'm considering buying a set of tires and rims from a private party and am not sure if they'll clear everything without problems. They're going on a stock 2008 Panel LS (no brake mods). The rims are a 5X110 bolt pattern and are 17x7.5. with a 45mm offset. The tires are 225/65/17s. From what I can determine online they should be okay EXCEPT I'm concerned about the offset. Before I plunk my money down, does anyone have a definitive answer? Much obliged.
Okay. Let me amend that a bit.
I can separate the tires from the wheels. Sooo... can I still use the wheels with lower profile tires? Still not sure about the offset (Sorry Don, even with the offset info I'm a bit lost... thanks though).
Thanks to both of you for your quick responses.
Definitely too tall. I found a chart, sometimes is more useful. I haven't verified it's accuracy.
Tire Height Chart
26.2" is the max height, or tire diameter. I've seen some say 26.3" , I don't know which is correct.
Tire Height Chart
Tire Width for a Wheel/Rim Size Chart
Joe, the wheel looks like a good fit, you can use these charts to help choose a tire size.
255 is kinda wide for a 7.5" wheel. 225/50-17 would be good.
