window switch replace
Old Nov 12, 2017 | 10:41 AM
suburban's Avatar
My 2008 HHR SS driver side power window switch for the front windows work intermittently. The back ones work fine. I ordered a replacement switch (controls all 4 windows). How hard to replace? Read one thread that said that you have to disable driver side air bag. Is this true? Please advise....Thanks, Wayne
Old Nov 12, 2017 | 11:34 AM
There are no air bags in the door. You should disconnect the battery negative before starting work on electrical system.
Remove the door panel, replace switch, reinstall door panel.
https://www.chevyhhr.net/forums/how-...removal-14040/
Old Nov 12, 2017 | 05:26 PM
Yup, it’s pretty straight forward, and yeah, please disconnect the negative battery terminal at the battery.
Old Nov 12, 2017 | 07:36 PM
I think you can do it without removing the panel. If you have the new one in hand you can see the tab that needs pressing and the tab that anchors.
pdmorris1
Jun 18, 2017 09:12 PM
El_Guapo
"How To" Tutorial Library
46
Jul 2, 2011 10:38 PM
jcbrowns
16
Feb 25, 2009 06:25 PM
imagepower
May 18, 2008 02:25 PM
airbuff1
Mar 5, 2007 01:15 PM
