Windows and mirror not working (click)
Old Sep 30, 2020 | 10:04 AM
Sam Avila's Avatar
So my daughter's 11 HHR has an issue. so the power mirrors are not working and 3 of the 4 windows do not roll down (only a click sound), the driver's side window goes down. The other doors the window will not go down when pressing the switch on the individual window (only hear a clicking sound). I'm wondering if I have to replace the master window/mirror switch on the driver's door? Any suggestions?
Old Sep 30, 2020 | 10:31 AM
PulpFriction's Avatar
Do the windows work using the switches on the individual doors?
Have you double-checked the window lockout button?
Does absolutely nothing work with the mirror switch, or does it only move in certain directions?
Old Sep 30, 2020 | 01:24 PM
You can clean the contacts inside the window master switch and in the mirror switch.
https://www.chevyhhr.net/forums/www....ad.php?t=62119
if this doesn’t fix the problem, or resident part out guy probably has a good used set of switches
https://www.chevyhhr.net/forums/www....ad.php?t=63306
send hellshotrod a PM
Old Sep 30, 2020 | 02:14 PM
Each door has it's own batt+ and ground. The master switch sends logic level signals to the door (up, down, lock). The only common spot is the fuse for all 4 windows. Each window has a logic board, not simple switches.
If you hear clicking the problem is most likely either the regulator or the motor.
The mirror switch is a common victim of moisture.
Old Oct 1, 2020 | 07:38 AM
Blue_SS's Avatar
If it's not a switch...
I had the weatherstrip at the bottom of the window stick to glass strong enough to do this on my Oldsmobile years ago. I never used the rear windows, and after 4 years, they got stuck. Took me a long while to find the cause.
fastsuv
Mar 6, 2021 11:55 AM
Leroy Cook
May 28, 2019 11:59 AM
Tanna Bowen
Apr 9, 2016 06:45 PM
jawzz1
Oct 28, 2008 08:05 AM
