GM NEEDS to put a recall on the vacuum pump assist problem!
Once again I go to get in my car like a normal person and because I didn't wait long enough for it to start and warm up like we're in the 1940s, I backed out of the parking spot and had no power brakes. GM needs to do an official recall because I cannot afford to go dump the money on the vacuum pump and it is a safety hazard. Those of us that still have this problem should not have to pay for it. It is not a repair is a blatant safety issue GM drop the ball on
From what I remember(this issue started back with the 1st SS's in 2008) GM did have a TSB and "special service fix" for this problem. Vacuum assist pumps were installed for those with automatic transmissions that were experiencing braking problems at startup.
My question is, why wasn't your's retrofitted with the pump at that time? If it is/has been a problem for this long, why didn't the owner or previous owner have the work done before.
Waiting 5-6 years down the road to now ask for a recall, well GM did something back then. Not their fault the owner didn't have the repairs made.
No need for a recall when they already offered a free fix before.
Just my 2 cents worth.
Dontcha think demanding recalls on old known issues is a really cheap shot, especially right now? The bandwagon is full.
Did you get an estimate?
Did you investigate how much the part would cost?
Did you find out how easy it is to install?
You do know that dealerships charge a higher labor rate than most shops? The Techs go to the same schools.
Try sending a PM to CCS, they will be chiming in here any minute anyway.
Maybe if they made a better product the cheap shots would cost more...
70K on my 08 Panel,purchased new in 07, it does not get babied, and only repairs (other than stash box latch recall) have been maintenance.
Nobody makes a 'perfect' car, but jeez, when you buy used you have to take into consideration how the previous owner used and maintained it.
Not a cheap shot. This is not a previous owner treatment problem. The dealer told me it's not a free fix. I have no idea why the previous owner didn't do anything if it was free then. GM customer care responded to me. We'll see what happens.
Yes it is a cheap shot!
"RECALL" is a very nice buzzword, it gets you noticed (that's what makes it cheap).
You went to ONE dealer, and I can guess from your general postings that there was an attitude problem. That goes for King Aire also.
The point was that the Original Owner should have also had the problem and could have easily had it repaired 5 or 6 years ago. Now you are just noticing it (I note you joined HHRnet in 2009), no doubt because you read a thread about it and there is a big recall going on now. I just don't believe it took you 6 years to care so much about an issue that you think is recall worthy.
"Maybe if they made a better product the cheap shots would cost more... " You do realize that YOU owned GM at the time your car was built, right? Where do you think all of that money is coming from?
Sour grapes.
Sour grapes.
Sour grapes.
Sour grapes.
I'm not your child.
