09 SS Turbo out
Old Mar 11, 2018 | 10:03 PM
ducky69247's Avatar
Originally Posted by donbrew
When did you clear codes and why?
I can tell because the EVAP tests are incomplete.
I don't know what that means, I just put the interface on to check for codes because there's no check engine light, but obviously I'm having problems. I barely managed to figure out how to do the test I posted. I'm not a mechanic.
Old Mar 11, 2018 | 10:06 PM
ducky69247's Avatar
Originally Posted by Cat Man HHR
When you shut the engine off there is no stored turbo pressure. You will only have boost under a load condition. It doesn't release pressure either, except for how the waste gate on it operates.
If the waste gate valve is hung open or missing, I can see you having a low boost condition.
I didn't presume to understand it, I know next to nothing about how an engine works, but these new cars are too technical for me. I read around the forums a while when I first got it, and that was how I understood what I read about it. Because I was concerned the first time I heard it.
Old Mar 12, 2018 | 07:04 AM
DrLoch's Avatar
One of the clicking sounds is the dumping/relieving of the injector rail pressure. The other I've heard is the EVAP solenoids. The EVAP solenoids on my truck are loud, in fact at one point when I didn't think I heard them, I didn't, truck threw a code solenoid underneath decided it' didn't want to work anymore.
Old Mar 12, 2018 | 01:21 PM
Cat Man HHR's Avatar
Ducky look at this:
Old May 19, 2018 | 02:29 PM
ducky69247's Avatar
Well, it doesn't seem like my problem was the Boost Control Solenoid. I installed the BorgWarner part, checked that the turbo wasn't damaged while I was down there, at the very least it spins freely, but my problem remains. Accelerating kicks the RPMs up, as the car struggles to maintain/gain speed, no indication of any boost.
Old May 19, 2018 | 02:46 PM
Have the OBD2 tests completed yet? If not it is because there is a check engine light code that is preventing the test from running. Which in turn would put the engine into "save me" mode.
Old May 19, 2018 | 02:51 PM
ducky69247's Avatar
Still no check engine light, no codes, and I don't know how to complete those tests.
Old May 19, 2018 | 03:18 PM
ducky69247's Avatar
123
mode $06 report generated by torque for android
vehicle manufacturer: Chevrolet
vehicle calibration id: 12629314
12633787
12629330
12629332
test report:
mid:$01 tid:$83
- o2 bank 1 sensor 1
max: 1.99882 min: 0.29988
test result value: 1.03066
pass
mid:$01 tid:$84
max: 0.06997 min: -0.06997
test result value: -0.00497
pass
mid:$02 tid:$05
rich to lean sensor switch time(calculated) - o2 bank 1 sensor 2
max: 400ms min: 0ms
test result value: 10ms
pass
mid:$02 tid:$07
minimum sensor voltage for test cycle(calculated) - o2 bank 1 sensor 2
max: 0.44969v min: 0v
test result value: 0v
pass
mid:$02 tid:$08
maximum sensor voltage for test cycle(calculated) - o2 bank 1 sensor 2
max: 1.14778v min: 0.44969v
test result value: 0.9494v
pass
mid:$02 tid:$81
max: 0.64026v min: 0v
test result value: 0.6305v
pass
mid:$02 tid:$82
max: 1.14778v min: 0.64026v
test result value: 0.65002v
pass
mid:$21 tid:$84
- catalyst monitor bank 1
max: 1.99882 min: 0.20301
test result value: 0.85888
pass
mid:$39 tid:$80
max: -4,915 min: -32,768
test result value: -4,982
pass
mid:$3c tid:$80
- evap monitor (0.040")
max: 0.59966 min: 0
test result value: 0.03767
pass
mid:$3d tid:$88
- evap monitor (0.020")
max: -10 min: -32,768
test result value: -58
pass
mid:$3d tid:$8c
max: 32,767 min: -8,192
test result value: 25
pass
mid:$41 tid:$85
- o2 heater monitor bank 1 - sensor 1
max: 1,302.80005°c min: 805°c
test result value: 819.60004°c
pass
mid:$42 tid:$81
- o2 heater monitor bank 1 - sensor 2
max: 806ohm min: 0ohm
test result value: 128ohm
pass
mid:$81 tid:$80
- fuel system monitor bank 1
max: 6.04% min: -6%
test result value: 0.51%
pass
mid:$81 tid:$82
max: 1.31925 min: 0.77958
test result value: 1.14247
pass
mid:$a2 tid:$0b
ewma misfire counts (average) for last 10 drive cycles - misfire cylinder 1 data
max: 65,535count min: 0count
test result value: 0count
pass
mid:$a2 tid:$0c
misfire counts for last/current driving cycles(calculated) - misfire cylinder 1 data
test incomplete or dependant test failed
mid:$a3 tid:$0b
ewma misfire counts (average) for last 10 drive cycles - misfire cylinder 2 data
pass
mid:$a3 tid:$0c
misfire counts for last/current driving cycles(calculated) - misfire cylinder 2 data
mid:$a4 tid:$0b
ewma misfire counts (average) for last 10 drive cycles - misfire cylinder 3 data
pass
mid:$a4 tid:$0c
misfire counts for last/current driving cycles(calculated) - misfire cylinder 3 data
mid:$a5 tid:$0b
ewma misfire counts (average) for last 10 drive cycles - misfire cylinder 4 data
pass
mid:$a5 tid:$0c
misfire counts for last/current driving cycles(calculated) - misfire cylinder 4 data
end of report.
Old May 19, 2018 | 04:05 PM
If you don't even look at the data you post, why bother? (rhetorical question)
Does your check engine light come on when you turn the key to "run".
I find it difficult to believe you have no codes with all of those misfires.
The test are run by the computer, when a test does not pass the code for that test is displayed on your scanner and usually the CEL illuminates. BTW, there is even a code for a broken CEL.
The $06 doesn't tell much to the normal user, you need to check for codes, there are 3 levels of codes; historic, current and pending. Different scanners use different words.
At this point I would suggest a fuel pressure, and a compression/leakdown, and an intercooler system pressure evaluations.
Old May 19, 2018 | 04:13 PM
ducky69247's Avatar
The light comes on, with all the others, when I turn on the ignition. There are no codes stored, that's all I can say, because that's all my reader (and the one at O'Reilly) tells me. I'm sorry I'm so stupid that you're once again asking "rhetorical" questions as such. This is stressful enough without that, thanks
