2007 hhr ls brake issues
Old Jun 1, 2018 | 11:59 PM
Briguy64's Avatar
replaced front wheel brake capiers and pads. new rear wheel cylinders, and master cylinder. bleed all the lines. brake pedal is hard until the car is started. then brake pedal goes to the floor and there is no brakes. cylinders and calibers are moving but still no brakes. at a lost what to do/check next.
Old Jun 2, 2018 | 01:00 AM
Welcome.
Did you bench-bleed the master cylinder before installing it?
ie: https://www.thoughtco.com/bench-blee...ylinder-281381
Old Jun 2, 2018 | 09:50 AM
Booster?
Old Jun 2, 2018 | 11:51 AM
Was the car having this problem before this work was done?
Old Jun 2, 2018 | 04:32 PM
Welcome to the site
Did you bleed the brakes in order?
RR,LR,RF,LF
Did you bleed the distribution block?
Arkygirl
Jan 29, 2023 09:48 PM
Michael Benedict
Aug 20, 2016 11:07 AM
LuckyLadySD
Jun 12, 2014 02:09 AM
Old Ray
Mar 29, 2008 02:29 PM
