93 octane 89 octane E85 in SS
Old Feb 11, 2012 | 07:14 PM
Ha Ha, that BC 94 chevron is crazy fun, my favorite part of the visit.
Old Feb 11, 2012 | 07:22 PM
Black C5's Avatar
They have 94 octane Under the Bridge?
Old Feb 12, 2012 | 07:57 PM
Chevy13's Avatar
I wish ethanol would completely go away
Old Feb 12, 2012 | 08:10 PM
Black C5's Avatar
I actually remember leaded pump gas over 100 octane.
The new cars and unleaded gas today are a lot less trouble, and technology has advanced so that today's cars were not even dreamed about back then. Anything in the muscle car era with the real horse power that the HHR SS has today would have been able to cruise at 9 or 10 mpg and require a tune up, points, plugs, carb work etc every 12,000 miles.
The 'Good 'Ol Days' required a LOT of maintainance...and fuel.
Old Feb 12, 2012 | 08:17 PM
chudlychudson's Avatar
Originally Posted by Black C5
Filled up with the second tank of gasoline yesterday. Mixed driving average for the tank is 27.0 mpg average, about 40 @ 40 and the check engine light went out after about 1/2 of the first tank.
Power is good, but the 104 E85 had a little more seat of the pants performance...
When I get my new shifter I will get some numbers from the track.
If I'm not mistaken, there are only 2 fuel maps in the stock tune. One for 87 octane, and one for 91 octane. I'm not sure that running 89 is going to give you any benefit over running 87. And the problem with running E85 is that the energy density is lower. Without an E85 fuel map, the engine will run lean as it won't be able to put enough fuel in to reach the right mixture. The check engine light probably has something to do with that. I also read somewhere that the stock fuel pump in the tank can't supply enough E85 to meet the high pressure pump demand at wide open throttle with the LNF.
Old Feb 14, 2012 | 10:35 AM
shael's Avatar
Originally Posted by Tyler Harvey
That's great Joe, I didn't know that. Here in Manitoba, we don't have Chevron. You're lucky.
you dont have petro in manitoba? they sell a 94 :)
Old Feb 14, 2012 | 11:40 AM
Hib Halverson's Avatar
DO NOT use E85 in an engine which does not have "Flex Fuel" engine controls and fuel system.
Do not be "seduced" by the idea that E85 at service stations is always 105-octane. Do so and you risk engine damage and fuel supply system damage.
E85 will damage the plastic, rubber and steel parts in a non flex-fuel fuel system. E85 is corrosive to metal parts of the fuel system which are not stainless steel.
E85 will cause the engine to run lean at wide open throttle and that is the kiss of death for a turbocharged engine. The reason this is a problem is because E85 requires a more rich air-fuel mixture at WOT than does "normal" gasoline.
Also, the E85 you may find in some parts of the country is inconsistent in its actual mix of gasoline and ethanol. It might be E85 but it also might be "E70" or "E60". This is because there is not much standardization amongst refiners and not a lot of regulation. This is also why flex-fuel systems have to "sense" the percentage of ethanol and alter the AFR accordingly.
Now, if your smitten with the idea of E85 and your HHR is a flex-fuel vehicle, there are a number of racing gasoline products which can be relied upon to be truly E85. Rockett Brand Racing Gasoline, for example, is always 85% ethanol and is always 112-oct. Rockett Brand E85 is popular with some drag racers who run cars which have fuel systems modified to be compatible with E85. For more info on 112-oct E85 see: http://www.rockettbrand.com/techsupp...ept%202008.pdf
JoeSchmoe's Avatar
Not everywhere.... on Vancouver Island the Petro Cans don't have the 94 octane. On the mainland, a few have it.
Chevron is the only company on the Island that has 94 octane and at every station too!
Old Feb 23, 2012 | 10:04 PM
Black C5's Avatar
Thanks Hib for your intelligent and educated comment directed to the HHR brotherhood! Informative comments like yours are what make the forums so much fun…Thanks again
Old Feb 23, 2012 | 11:15 PM
ATLsilverSS's Avatar
running ethanol requires the proper tune for it and the blend that you are running. it also requires frequent datalogging to make sure that you are tuned for the proper blend. it has been said several times that ethanol will not damage anything in our fuel systems. i am getting an ethanol tune after my clutch gets installed. e85 to a e47 blend is good for about 10% more whp over running straight 93 octane pump gas.....with a tune only of course
