ashamed
Old Nov 26, 2010 | 08:41 PM
FURIOUS10's Avatar
ashamed
i have 2010 auto.i had a Subaru pull up at light when green punched it i went nowhere what happened?
Old Nov 26, 2010 | 08:43 PM
No traction?
Old Nov 26, 2010 | 08:57 PM
FURIOUS10's Avatar
No traction?
no power just rolled. i let off then gently accelerated away.
Old Nov 26, 2010 | 08:59 PM
hyperv6's Avatar
Very possible. You kind of have to walk these cars out even with comp mode on. The tires have a hard time with grip.
I know with the GM turbo upgrade punching it with the auto even rolling 25-30 MPH will light the tires up.
You kind of have to learn this car. Even with little lag on the turbo the power will still roll in hard once it catches up.
Old Nov 26, 2010 | 09:02 PM
hyperv6's Avatar
If the power dropped it could be a overboost.
The waste gate poped and you lost all your boost. It will feel like the engine died but it will still be running.
Once it recovers it will drive away normal.
Old Nov 26, 2010 | 09:07 PM
Gas Man's Avatar
Hell yeah put it in rain and my front tires spin up at 60mph when I drop the hammer. Nutso
Old Nov 26, 2010 | 09:08 PM
FURIOUS10's Avatar
can cold weather have anything to do with it? sat outside for a couple of hours, 30 and windy. traction off . did it at 2 different lights before that it took off. this is my first turbo.
Old Nov 26, 2010 | 09:29 PM
moonsign's Avatar
When you dropped the hammer, did it spin the tires, or just fall on it's face?
If you WOT, then ease off a little, it will dump boost, and you have to stand on it again, WOT, to get the boost back up, and don't backpedal.
I have Trifecta dual tune, and traction is always a problem with tune on, and even WOT with stock tune. Cold weather or rain, I keep stock tune on, as Trifecta tune will light the tires real quick, up to about 55mph, and get squirley as hell. Even in the dry with tune on, it will smoke the tires easy.
Once it hooks, she hauls butt. I get around 25-26 lbs. boost, WOT.
If it's not boosting, and just shutting down , you have a problem. Keep you leg in it, and if it's still not boosting from the get go[up to around twenty lbs.], WOT, then get it checked out. If you have stage 1 ,then you should be getting at least 20lbs. boost and more. Stock tune around 15 lbs boost. Just my 2 cents. "Moon"
P.S. cold weather should make it run harder. I can tell the difference when it's chilly[out here on the right coast, anything under 55F, is chilly].
Old Nov 26, 2010 | 09:31 PM
FURIOUS10's Avatar
If it's not boosting, and just shutting down , you have a problem. Keep you leg in it, and if it's still not boosting from the get go[up to around twenty lbs.], WOT, then get it checked out. If you have stage 1 ,then you should be getting at least 20lbs. boost and more. Just my 2 cents. "Moon"
fell on its face
Old Nov 26, 2010 | 09:34 PM
moonsign's Avatar
Need to have it looked at. Thats not normal, by any strech. Grt it back to normal, and with the stock tune, you should give the Subby a good run. With tune he's toast[unless he too is modded]. "Moon'
