ashamed
Old Nov 26, 2010 | 10:45 PM
BlackknighT's Avatar
My little 2.2 chirps on a punch with an AT. Love to do it next to all the PT Losers around here. If I chirp and you don't with your SS-better have the Dealer look at it...
Old Nov 27, 2010 | 09:30 AM
camaro98z28's Avatar
Hmmmm. That is not normal at all. Try it again and see if it does it. I light the tires up every time. I hate first gear and should be illegal to or banned from this vehicle. LOL
Originally Posted by FURIOUS10
fell on its face
Old Nov 27, 2010 | 09:37 AM
hyperv6's Avatar
can cold weather have anything to do with it? sat outside for a couple of hours, 30 and windy. traction off . did it at 2 different lights before that it took off. this is my first turbo.
Temp will not effect this.
I agree I would have it looked at.
Do you by chance have the GM turbo upgrade? Under hard acceleration it can dump the boost if you hit it hard on the gas. The lower map can hit the AC line or compressor if it is not clearanced properly.
Mine would spool to about 7 PSI and die and go no where. I found the Map hitting the AC unit and would short out. Normal driving was uneffected as the engine did not torque back far enough.
If you are stock it may be something else.
Old Nov 27, 2010 | 11:30 AM
This time of year it just ain't right to say 55 is chilly."REALLY"
Old Nov 27, 2010 | 12:40 PM
moonsign's Avatar
I spoke too soon and zissed off mother nature. The last couple days it got down to almost freezing around here, and some white stuff on the higher hills.
High today is 52. This lower air temp makes the SS run harder. Going to the store this morning, saw steady 26 lbs. boost, and lots of wheelspin. Whoya! "Moon"
Old Nov 27, 2010 | 12:47 PM
FURIOUS10's Avatar
no stage 1 kit all stock. 1st time this has happened. all other times have to hold on with both hands to control this little beast wagon. i will try again today.
Old Nov 27, 2010 | 04:56 PM
hyperv6's Avatar
Son in these here parts that is just partly cloudy and mild with a light frost.
Old Nov 27, 2010 | 05:11 PM
Sunflowerhippi's Avatar
I can say from my SS when my wastegate failed it caused a smiliar problem, and a few days later my CEL came on.
Old Nov 29, 2010 | 09:03 AM
jerSSey HHR's Avatar
If I'm not careful I could wear my tires to the rims in about 2 months with the amount of spinning it wants to do upon takeoff. Especially if you are near the large white stop bar on the pavement at an signalized intersection. Those things are like spinning on ice.
HillsdaleHHR
Aug 28, 2009 08:09 PM
