Big turbo and cams on an automatic
I have an '09 automatic and I plan on installing a .63a/r gt2871r and cams in my hhr. The cams are machined Equinox cams with a larger fuel lobe. First question, since it's an automatic and holds boost during shifts, a VTA blowoff valve wouldn't hurt performance, would it? Second question, the cams are equivalent to ZZP stage 2 cams with the bigger lobe, I need valve springs, right? Third question, I figure I'll be close to 400whp and I have no idea what the torque will be like, will the transmission hold up? I have the TTR motor mount, would a decent trans mount help protect my trans from breaking?
Thanks
Thanks
Per GM....
2009 Hydra-Matic 4T45 Transaxle ( MN5 ) Prduced from 3/18/2008 onward.
Type: four speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with electronically controlled torque converter clutch.
Engine range: 2.2L - 3.5L
Maximum engine torque: 221 lb-ft (300 Nm)
Maximum gearbox torque: 325 lb-ft (440 Nm)
Gear ratios:
First: 2.95
Second: 1.62
Third: 1.00
Fourth: 0.68
Reverse: 2.14
They'll take 300+ hp reliably, 400 hp and above may require some beefing up of internal components.
Try a Google search on Performance Hydra-Matic transmission builders.
Gear ratios:
First: 2.95
Second: 1.62
Third: 1.00
Fourth: 0.68
Reverse: 2.14
if you email zzp they may give some advise. I know there's company right now that will go through the trans and gears put a bigger torque converter and make it a 3 speed. I read the article and was empressed, it can handle a lot more HP. I would definitely get a good trans cooler, like this one,
Transmission Rebuild Components & Cooling - MAPerformance
Tim
Tim
Walking the fine-line, between massive torque / massive destruction...
Not for the faint of heart...
But the 4t45e, handles it well, just as strong today, as it was 5 years ago...
The guy that rebuilt my auto trans (planetary gear blew up) at 66,000 didn't seem to think it was built to handle the tune....When I told him it was tuned and probably close to 300 lbs/ft of tq he was sure that was the cause...I also have no changes to the transmission with my tune....so that could have been my problem?
You have the automatic? What turbo are you running? I know a small T3 isn't very easy on the transmission because it's so snappy.
