Big turbo and cams on an automatic
Old Jun 23, 2015 | 10:39 AM
OshawaHHRss's Avatar
Originally Posted by black Tara
if you email zzp they may give some advise. I know there's company right now that will go through the trans and gears put a bigger torque converter and make it a 3 speed. I read the article and was empressed, it can handle a lot more HP. I would definitely get a good trans cooler, like this one,
Transmission Rebuild Components & Cooling - MAPerformance
Tim
Wouldn't a higher stall smaller diameter torque converter be better? I daily drive mine and sometimes take it to the local track on lapping days, so I need the 4 speed. But the trans cooler is a good idea
Old Jun 23, 2015 | 02:15 PM
2005HHRauto's Avatar
Originally Posted by OshawaHHRss
You have the automatic? What turbo are you running? I know a small T3 isn't very easy on the transmission because it's so snappy.
Stock...
Old Jun 23, 2015 | 02:16 PM
Stock Convertor is fine.
I can boost-launch off the line, holding 3,500 rpm...
2005HHRauto
Racing Discussion
Sep 14, 2013 11:50 AM
Jay Budget
2.2L Performance Tech
Apr 7, 2008 04:12 PM
LT1GMC
Mar 1, 2008 04:59 PM
