boost gauge ?
Old Apr 1, 2009 | 12:44 PM
imagepower's Avatar
Originally Posted by tony326
part# 15234699 moulding only, grey color list price $51.57
Great, thanks!!
Old Apr 1, 2009 | 12:46 PM
tony326's Avatar
there was a wire harness dont know what it was for since i was installing the aeroforce gage i didnt check the harness connection, there is a harness part number but was told it not available, i will post pics later today
Old Apr 1, 2009 | 12:51 PM
JeramieJJ's Avatar
Excellent. I want to see the Aeroforce. I like my analog, but might want a second gauge in the future.
Old Apr 1, 2009 | 12:57 PM
andyb's Avatar
thanks to all for the fast replies & part #'s. I really want to install the factory boost gauge & if anyone out there can confirm if the wiring for the gauge is in the a pillar, if the car came with the display, & will be an easy job? by the way, I may also remove the display & replace with the glovebox, but only if i can install the factory gauge. how much is this aeroforce gauge?
Old Apr 1, 2009 | 01:02 PM
gcsd3742's Avatar
AEROFORCE GAUGE ENOUGH SAID....Look at my Photobucket link you can see the Aeroforce working. You dont want the analog its crap and like said previously wiring m ay not be there. Aeroforce plugs right into your OBD2 port and you live and running
imagepower's Avatar
Here's the link:
http://www.aeroforcetech.com/products_interceptor.html
Old Apr 3, 2009 | 11:49 AM
andyb's Avatar
Question
for those of you that removed the a pillar trim panel, does it just pull of, I'm only asking because it says airbag on it & want to know if there are any issuses i need to be aware of.
Old Apr 3, 2009 | 11:50 AM
gcsd3742's Avatar
under Airbag threres a screw that needs to be removed after that just pull it off
Old Apr 3, 2009 | 12:02 PM
andyb's Avatar
Arrow
thanks for the fast reply. since you had it off, & i assume you had the analog gauge, how is it hooked up? i assume it has a factory style connector.
do you want to sell your factory gauge?
Old Apr 9, 2009 | 10:31 PM
tony326's Avatar
UPDATE i ordered another gauge pillar, i came in wrong no gauge hole, the dealer who sold me the first one stated that they took out the gauge and tweeter 25799244 and sold me the left over part and used the the part number part# 15234699 to get a price, it's the stock replacement no hole for gauge, u can only get the compete pillar kit $255.00
