The Brake Fix Is In
Old Jan 5, 2010 | 05:50 AM
  #201
hyperv6's Avatar
Originally Posted by bobiroc
I am pretty sure the ECBM calibration should have been done the first time. At least that is what they did when they installed the aux vacuum pump in my HHR. It has been good ever since that has been done.
I am sure they flashed it but did they use the correct flash as there are more than one. Also many have had the wrong flash put on and not had an improvment.
Old Jan 5, 2010 | 09:03 AM
  #202
ChevyMgr's Avatar
Originally Posted by jerSSey HHR
I gave them two chances and they really blew it. I can only hope they send me a customer satisfaction survey.
You will only get a survey if they did a warranty repair, that is submitted by the dealer to GM for payment. If they only were ordering parts then no survey would be generated. And if you go to another dealer for the repair, and they submit a claim to GM, the survey will be on that service visit.
All you have to do is check the dealer name at the top of the survey to make sure you are grading the correct dealer.
Old Jan 10, 2010 | 09:52 AM
  #203
sumo1's Avatar
Talking vacuum boost - brake issue
Happy New Year All!
I have an '08 SS 5-sp which had intermittant hard brake pedal on start up cold... have had car the dealer three times for issue, and finally got it right on 3rd attempt. they replaced booster and check valve and no recurrance of issue. Some times you have to just hang in there with them.
Old Jan 11, 2010 | 10:03 PM
  #204
IgottaWoody's Avatar
Originally Posted by sumo1
Happy New Year All!
Chances are it will show back up... a lot of us that had this problem had it show up after a few thousand miles.The real fix is the pump addition..
if you watch at start up, there is a slight amount of turbo air build up when cold( enrichment) so not much vacuum being made, after eng stabilizes the vacuum builds and booster fills.....but then again, you may be the exception and actually have a legit fix...keep us posted.
Old Jan 12, 2010 | 08:02 AM
  #205
ChevyMgr's Avatar
sumo1 has a 5 speed. You don't add the pump to those.
Old Jan 12, 2010 | 09:12 PM
  #206
Ah yes...you are correct......so his was a different issue.
Old Jan 12, 2010 | 09:36 PM
  #207
ChevyMgr's Avatar
The fix makes sense for a hard pedal. There have been some other members that complained of the pedal being hard on cold starts with 5 speeds, so hopefully this will help them get theirs fixed.
Old Feb 2, 2010 | 04:14 PM
  #208
patrick49's Avatar
Picked up my car today after having the brake vacuum pump installed. I've had the GMPP turbo upgrade for a while now and the car seems legitimately more responsive than it was before I got the brake fix. At first I thought it was just because I'd been driving a Saturn Aura for the weekend, but I went out in it again and it still seems like it's taking off faster. Am I imagining this or is there some reason this might be happening?
Old Feb 4, 2010 | 04:38 PM
  #209
Temple of Zoom's Avatar
Taking my SS in next week to have the vacuum pump brake fix performed. For those who have had this done what should I expected regarding the splicing and addition of wires needed for this repair? I realize the TSB instructs the tech to route all wires in existing wire loom or add loom when needed but my experience has been repair technicians don't always perform repairs to a level of factory appearance particularly when it involves splicing or adding wires to the factory harness.
If it doesn't reach my level of expectation I will have them make any changes necessary. Just wanted to get a feel for everyone else's experiences. My HHR is not a daily driver so under hood appearance is of equal importance as the mechanical repair itself.
Old Feb 5, 2010 | 10:55 AM
  #210
irloyal's Avatar
I had to take mine back. The installation was pretty poor. The wife picked it up after the install and drove it home. I got home, opened the hood, and called the dealership to tell them i was coming in the next day. I talked to the service manager, told him when I brought it in I told the writer to make sure they took their time and did it right, I wouldn't need the car right away.
Then I showed him the mess of cable ties, electrical tape, and brought out my trophy and pictures from a car show and asked him if he thought it was as clean as I had kept it. He said they didn't usually replace wire wraps, looms etc they just incorporated what was there. I showed him loose wires, crappy ties, electrical tape and said if this was how they treated their customers cars, fine, I'll go somewhere else. He said they would fix it. They did a pretty good job fixing it after I complained, but ChevyManager clued me in to a better shop locally that I plan on using from now on.
