Can the Ecotec LTG (Gen 3) motor be used to replace the LNF (Gen 2) motor in my 08 SS
I have been working to save my 2008 HHR SS which has a damaged motor from a timing chain tensioner failing.
I found a 2014 2.0 Ecotec LTG (Gen III) with 7K at a very good price. I cannot find any information about being able to use this motor instead of the LNF (gen II) motor.
Is there big differences which prevent this engine swap. Can the original ECU be used with a gen lll motor
Any information or advice would be appreciated. If there are post about this kind of swap sorry about repeating as I could not locate.
If your ECU could be used it would need new firmware.
Anything is possible, if you got the money. This would not be a project for a first timer.
The physical fit may be good, you would need to measure. The intercooler is probably different. The wiring harness is most likely different. I think the transmissions are the same, but probably programmed different.
You could probably get away with using the donor ECU and TCM.
I Googled the two engines and they are worlds apart, however if you are able to have a look at the engine of a Cadillac ATS you could measure and maybe I'm out in left field but it looks like a North / South orientation
The ATS is rear wheel drive thus the orientation difference. A more correct view would be found in the Buick Regal GS, Verano and Chevy Malibu.
Well, it appears that the intake and exhaust systems are on the opposite sides with the newer LTG compared to the old LNF.
This alone would be a HUGE obstacle to overcome in getting that engine in your SS.
I'm sure there's about a million other reasons/mods/swaps that would need to be done to make it work.
In my book it's not worth the time, aggravation or extra money you would need.
The gm engines that are almost a direct swap are the LHU and LDK. You may be better off goin with the LDK because it is higher compression and internals are said to withstand 500hp. ZZP sells a new LDK long block for pretty cheap actually, and will give you everything you need for the LDK swap.
