Clutch upgrade?
Old Jun 4, 2012 | 02:25 PM
AJL08SS's Avatar
Clutch upgrade?
Out of curiosity, I don't see many people mentioning clutch upgrades for these cars. When do our stock units let go? It feels fairly strong, but then again I have not done any modifications yet.. and since GM doesn't void the warranty for the Stage 1 upgrade (315-340 ft-lbs), it only makes sense that even 340 ft-lbs of twist isn't stressing the clutch too much.
Old Jun 4, 2012 | 04:33 PM
foolmoon_design's Avatar
Your gonna need a clutch. Check ttr.
Old Jun 4, 2012 | 06:50 PM
havoc3d's Avatar
Mine has started to slip a bit at 100k. If I'm gently cruising on the highway in say 4th then gun it, when the boost builds up the tach goes a little jumpy. Not sure what I'm going to do for replacement. I first noticed it about 10k miles ago, and my usual shop wants about $700 to replace it (about $500 if I bring my own clutch) and I have other bills...so the easy answer was don't stomp the throttle in 4th from low rpm
Old Jun 4, 2012 | 07:22 PM
ATLsilverSS's Avatar
Depends how uou drive it. With any tune available for this car the clutch will slip. To make the stocker last dont get into boost in too high of a gear. As far as what to get i run a ky stg3. I have a write up and an install how to (that i borrowed) on here simewhere
Old Jun 4, 2012 | 07:42 PM
THE BATMAN's Avatar
93,500 miles on my clutch, Still holds, No problem.
Old Jun 4, 2012 | 10:04 PM
lady3bglover's Avatar
Hubby had to replace his at over 400 Ponies stocker wouldnt hold... He did a Spec 3+ http://www.specclutch.com/cars/Chevy/HHR/2008/Single the Spec clutch is also in the Honda at over 700 Ponies. Turboed and 100 shot of NOS and it holds...http://s84.photobucket.com/albums/k37/gcsd3742/Texsin/ So with that being said I highly believe in them...
Old Jun 4, 2012 | 10:09 PM
EcotecRacer's Avatar
Go ky clutch!
Old Jun 5, 2012 | 10:04 PM
mightymouse's Avatar
yeah i went with spec and told eric about it,i liked my spec. held strong for three years till i recently traded the car. going to buy another one for the balt.
Old Jun 19, 2012 | 06:15 PM
RobSSTurbo's Avatar
I order a ky clutch and can't wait to install it.
Old Jun 19, 2012 | 09:08 PM
TurboTechRacing's Avatar
Former Sponsor
Good answer
Yes a KY clutch kit is your best choice.
