coolant & oil mixing
Old Jun 27, 2021 | 03:20 PM
  #31
Lonwane's Avatar
1- Dexcool is recommended by GM for GM vehicles.
2- Dexcool won't damage aluminum.
The green stuff is for steel blocks, not aluminum.
Old Jun 27, 2021 | 05:49 PM
  #32
And you did change the thermostat with an AC Delco 131-158, right?
the green stuff was great for a cast iron block and head engine of 20 or more years ago
Old Jun 27, 2021 | 07:58 PM
  #33
will1528's Avatar
had a garage do it. They got the oil cooler & thermostat from a local Chevy dealer. Hopefully it’s the right one Temp now gets no hotter than 185
What is a 131-158 what’s the temp. It will open
Old Jun 27, 2021 | 09:24 PM
  #34
You should contact the shop, find out which thermostat they installed. It matters.
Old Jun 28, 2021 | 05:34 AM
  #35
It’s a 180 degree thermostat, your invoice should show the part number
Old Jun 29, 2021 | 02:09 PM
  #36
will1528's Avatar
where is the radiator drain plug on these cars or do they have one --been taking the lower radiator hose off which is a pita in itself -- having to flush multiple times to get the oil residue out
Old Jun 29, 2021 | 03:23 PM
  #37
The rad drain is down on the passenger side of the rad facing the engine
It’s conveniently placed above the v shaped brace allowing the coolant to spill everywhere, so make sure Fido isn’t around to lick it up! Not good for animals!
Old Jun 29, 2021 | 08:23 PM
  #38
Actually the plug is not supposed to be removed; It is a spigot and the fluid drains down the pipe that you think is only the mount.
Old Jul 21, 2021 | 03:42 PM
  #39
will1528's Avatar
need advice please
Ok I posted some while back about oil in my coolant -- replaced the oil cooler & thermostat --flushed rad. 4-5 times filled with Dexcool still when you poke your finger in the top of rad. it is very oily -Could this be possibly be residue from when it gummed up cloggeg the thermostat & overheated -- A compression test was performed along with a leak down & a combustion (sniff )test all was good !after the work was done .
If I am still getting oil in the coolant after replacing the oil cooler (oem GM) since oil & coolant run through the turbo -Is it likely the turbo seals are shot -- I cant think of another place where oil could be getting in the coolant -- Am I right --think the tests that were performed would tell me if it was a blown head gasket or cracked head or block -- About ready to upgrade the intercooler & a few other mods but dont want to if the turbo is shot - Idont think there is any test to see if the seals are bad in turbo ,,are there? Still building good boost 22-23
Old Jul 21, 2021 | 04:35 PM
  #40
https://www.chevyhhr.net/forums/hhr-...-mixing-64332/
Gee, I wasted my words.
