Dressing Up the Winter Wheels
I have been running stock steel 16" wheels and the OEM hub caps on my SS with Blizzaks the past two winters. They work great but I have been wanting a little different look. I like the black steel wheel look on my black SS only if I could find a center cap to cover the hubs. I am not sure how this is going to work but I just bought a set of (4) new 87-90 Chevy Beretta center caps off of eBay for $10. I will have to modify them a little as the lug pattern is 5 x 100 mm. My plan is to open up the holes in the caps and use a trim washer of some kind to cover the oversized holes and then retain the caps with the plastic lug nuts from the stock hub caps. I will post some pics once I get the center caps and start messing around with them. G.B.
https://www.chevyhhr.net/gallery/sho...hp?i=26792&c=3
