E47 tune
Old Jul 31, 2014 | 03:56 PM
HHR08SS's Avatar
as I understand it ethonal has a much higher octane but not as much"energy" per gallon Vs gasoline. Ethonal burns at lower temp as well. that means less MPG for E85 vs gasoline or E47. so on big turbos etc they often need bigger injectors and cam pump lobes to keep up with the additional fuel needs. that being said it might be easer to just run a straight 85 tune as long as you can readily get it.
Old Jul 31, 2014 | 05:13 PM
y2k103's Avatar
Wow, I didn't know that, plus you answered my next question about the octane. (the station near me say 105 octane on them) So it sounds like I would need to change my injectors to really see any kind of a improvement. Now I understand why the E47 mix. Thank you for the info.
Old Jul 31, 2014 | 07:40 PM
2005HHRauto's Avatar
E47 has been proven to be the best fuel for the LNF engine.
No fuss, no muss, plain & simple.
You don't have to worry about changing injectors, or anything...
I'ts the best "bang-for the-buck", mod that you can do, with the greatest rewards.
A truly simple mod, easy to fill your tank with a 50/50 mix.
Each "hash" mark on your fuel gauge is 2 gallons, BUT, there is trick to this.
When filling, always subtract one.
So you pull up to the pump, down 6 "hash" marks on the gauge, times 2 = 12, minus 1 = 11. I then pump 5.5 gallons of E85, & 5.5 gallons of premium gas.
Plain & simple, I have been doing it this way for 5 years now...
So much smooth power with E47.
I can "floor" the petal at 40mph, & burn rubber...
if I stay out of boost, when going to the track, I can get 30mpg...
Old Jul 31, 2014 | 11:10 PM
cj krause's Avatar
hey 2005, says you exceeded your private messaging total. LOL
cant email you
i have some questions
cj @ cjsperformance . com
Old Aug 1, 2014 | 02:22 PM
cant email you
I can be reached at:
Lindadave83@hotmail.com
Old Aug 1, 2014 | 03:42 PM
  #26
XtremeSS's Avatar
So I loaded up the e47 tune, and headed to the nearest e-85 station. When I got there I saw this:
With a "minimum" rating of 70% ethanol, should I make the fuel mixture like 55% e85 and 45% 91octane?? Or should I just do the 50/50 mix regardless??
Old Aug 1, 2014 | 05:31 PM
  #27
Just go 50/50...
The ECM will take care of it...
I used to test my mixture, E70 is fine...
I've stayed with a 50/50 mix for 5 years now, the ECM will easily adjust , for E70...
Old Aug 1, 2014 | 06:01 PM
  #28
XtremeSS's Avatar
Originally Posted by 2005HHRauto
Just go 50/50...
Gotcha, thnx.
Old Aug 2, 2014 | 09:54 AM
  #29
y2k103's Avatar
Thank you so much for the info, I give it a try.
Old Aug 2, 2014 | 10:18 AM
  #30
But, you will still need the E47 tune to run that mixture.
