Emmissons Testing HELP!
Old Aug 15, 2012 | 11:55 AM
bad03xtreme's Avatar
Originally Posted by solman98
If all they were looking for is if an idiot light was on, there would be no need to even plug into the OBDII. They scan they complete is looking for more than just that. This is why more tuner programs are getting warrenty claims denied. They can tell if something has been altered that shouldn't have been.
In this case, it seems the OBDII test wouldn't complete, so it failed. Like not being able to read the cat....
If that was the case wouldn't it be triggering a CEL then?
Old Aug 15, 2012 | 11:58 AM
solman98's Avatar
NO, his tune is taking care of the CEL, it's just not smart enough to fool the tester.
Old Aug 15, 2012 | 12:16 PM
I just found this after some research.
What could cause my vehicle to be not ready?
Vehicles that are not ready do not always have something wrong with them. The following situations may cause the vehicle to be not ready.
  • Recent vehicle repairs or maintenance in which Diagnostic Trouble Codes (DTCs) have been cleared with an OBD scan tool.
  • A recently disconnected or replaced battery.
Have you recently done either of these things?
Old Aug 15, 2012 | 01:45 PM
RobSSTurbo's Avatar
I wonder if I am the only one notice that he is tuned by BYT aka backyard turbo aka nick. What is happening is he has a catless down pipe and nick tuned for that which he would turn off the cat warmup in the PCM which in return since the warm up is disable that test would be incomplete.
Old Aug 15, 2012 | 02:40 PM
solman98's Avatar
Kinda what I was saying when I stated his tune took care of a CEL lit on the dash by the tune. But the emission test is still looking for something that isn't there. I don't know what his tune entailed, but most of them tune to not light up a CEL for things like this.
Old Aug 15, 2012 | 05:43 PM
  #26
db/sb's Avatar
Ahh, okay. That would cause the vehicle to fail, or more accurately, not complete the I/M Readiness Monitor Status test. Essentially, it looks for all of the components of the emissions control system, i.e. Oxygen Sensor, Catalytic Converter, EGR, etc. If it's unable to read the status of the cat, or any other component, the test won't complete. I could go into more explanation but it could get really long winded. Easier to look it up.
Old Aug 16, 2012 | 02:16 AM
  #27
Might it also require a certain number of drive cycles to complete before it clears the Not Ready status?
Old Aug 16, 2012 | 06:28 AM
  #28
db/sb's Avatar
It won't ever 'clear' the status if one of the items it's looking for is not there.
Old Aug 16, 2012 | 08:19 AM
  #29
foolmoon_design's Avatar
He could have the o2 turned back on and then just clear the codes when they come up. On a very rare occasion I throw a code, but usually only after the car has set a few day.
Old Aug 16, 2012 | 10:01 AM
  #30
db/sb's Avatar
It isn't about codes, it's about the I/M readiness monitor.
