Fuel in oil (a lot) with new LDK motor
Old May 27, 2017 | 01:52 PM
HHRssrfun's Avatar
Originally Posted by Oldblue
Are they gas soaked! The combustion chambers should be full of fuel and the fuel level in the gas tank go down accordingly
Looking forward to checking them out.
Old May 28, 2017 | 12:33 PM
Cat Man HHR's Avatar
I don't think you should go overboard. Fuel into the crankcase points to the fuel pump before injectors.
An injector would give you some type of miss or poor performance. Maybe not even idle smoothly.
Change that part out with the oil and monitor the oil level from there.
Did the oil light come on at any point?
Old May 28, 2017 | 03:10 PM
HHRssrfun's Avatar
Cat man thanks for the advice. Just finished the Indy 500. Out to the shop to check plugs. I never did get a miss or code and it idled just fine. So I am hoping that the HPFP was the problem. It doesn't smell like fuel as much too. It has fresh oil now.
I will update on the condition of the plugs and thanks for all the help.
Old May 28, 2017 | 05:02 PM
HHRssrfun's Avatar
Ok, all 4 spark plugs looked great. Tan and gapped to 33 thousands.
And no fuel smell. Looking more like the problem was the HPFP and not the Injectors
I will update if anything changes.
Old May 28, 2017 | 05:29 PM
Don't reinvent the wheel. Go with what is logical.
Old May 28, 2017 | 09:39 PM
Don't ever touch the whisker on a Iridium plug with anything! Even checking the gap can damage them.
Old May 29, 2017 | 12:44 PM
HHRssrfun's Avatar
Too late. But didn't hurt them. Runs great. I never had a problem with the iridium plugs in my Ducati. Just need to be gentle.
Old Jun 17, 2017 | 06:04 PM
How's this issue going, Randy?
drummerboy0088
Jun 12, 2017 12:28 PM
Powermizer
2.0L Performance Tech
210
Apr 11, 2017 02:57 PM
JeramieJJ
Mar 24, 2017 08:44 AM
Tyler
Jun 28, 2016 11:42 AM
xzombiex66
Apr 6, 2008 11:34 AM
