Gear ratios / RPM @65Mph
Old Dec 15, 2008 | 04:15 PM
XXL's Avatar
XXL
Originally Posted by esmarkey
Can't tell you about the auto, but here is the gears for the SS manual:
1st = 3.38
2nd = 1.76
3rd = 1.18
4th = 0.89
5th = 0.07
Final drive ratio = 4.05:1
5th doesn't look right... otherwise we've got a theoretical top speed of about a bajillion mph.
Here's the math on drive ratio per gear--
1st = 3.38 = 13.689
2nd = 1.76 = 7.128
3rd = 1.18 = 4.779
4th = 0.89 = 3.6045
5th = 0.07 (??) = .2835 (??)
Final = 4.05:1
1st = 2.96 = 9.7384
2nd = 1.62 = 5.3298
3rd = 1.00 = 3.29
4th = .68 = 2.2372
Final 3.29:1
Old Dec 15, 2008 | 06:11 PM
Nebulous1's Avatar
1st = 3.38 = 13.689
2nd = 1.76 = 7.128
3rd = 1.18 = 4.779
4th = 0.89 = 3.6045
Final = 4.05:1
1st = 2.96 = 9.7384
2nd = 1.62 = 5.3298
3rd = 1.00 = 3.29
4th = .68 = 2.2372
Final 3.29:1
5th = 0.7
Old Dec 15, 2008 | 06:12 PM
Clevelandhhrss's Avatar
1st = 3.38 = 13.689
2nd = 1.76 = 7.128
3rd = 1.18 = 4.779
4th = 0.89 = 3.6045
Final = 4.05:1
1st = 2.96 = 9.7384
2nd = 1.62 = 5.3298
3rd = 1.00 = 3.29
4th = .68 = 2.2372
Final 3.29:1
Transmissions
GM Powertrain Sweden F35 5-speed manual / Hydra-Matic 4T45 4-speed automatic
Gear ratios: (:1):
First: 3.58 / 2.95
Second: 2.02 / 1.62
Third: 1.35 / 1.00
Fourth: 0.98 / 0.68
Fifth: 0.69 / –
Reverse: 3.31 / 2.14
Final drive ratio: 4.17:1 / 3.29:1
https://www.chevyhhr.net/forums/hhr-ss-45/2008-hhr-ss-frequently-asked-questions-9989/
Old Dec 15, 2008 | 06:37 PM
ChevyMgr's Avatar
You would need a flux capacitor which could produce 1.21 gigawatts of electrical power to obtain those speeds. I can't remember where I heard that.
Old Dec 15, 2008 | 06:38 PM
Nebulous1's Avatar
Originally Posted by Clevelandhhrss
Transmissions
Gear ratios: (:1):
First: 3.58 / 2.95
Second: 2.02 / 1.62
Third: 1.35 / 1.00
Fourth: 0.98 / 0.68
Fifth: 0.69 / –
https://www.chevyhhr.net/forums/showthread.php?t=9989
Are you sure those are the correct numbers? Check out http://media.gm.com/us/powertrain/en...08/08truck.htm. Check out the spec sheets for the LNF's transmissions, both 4T45(MN5) and F35(MU3).
4T45/MN5 shows:
First: 2.96
Second: 1.62
Third: 1.00
Fourth: 0.68
Reverse: 2.14
Final Drive Ratio: 3.05, 3.29
F35/MU3 shows:
Gear ratios: MU3
First: 3.38
Second: 1.76
Third: 1.18
Fourth: 0.89
Fifth: 0.7
Reverse: 3.17
Final Drive Ratio: HHR SS - 4.05
Old Dec 15, 2008 | 06:59 PM
LT1GMC's Avatar
One must remember that you have to multiply the final drive ratio by the transmission ratio to get the OVERALL ratio, IE: 4.05 final drive by .7 5th gear = 2.835
Example MPH x GEAR RATIO x 336 / TIRE DIAMETER = RPM
60 x 4.05 x .7 x 336 / 25.25" = 2263 RPM @60 MPH
(4.05 x .7 = 2.835 overall Gear Ratio)
Old Dec 15, 2008 | 08:54 PM
XXL's Avatar
XXL
Like I did in my post above?
Either that, or a darned good intercooler on the La Machine.
Old Dec 16, 2008 | 10:11 AM
cannuck's Avatar
at what mph does the auto shift for each gear at normal acceleration occur
Old Dec 16, 2008 | 12:47 PM
Nebulous1's Avatar
Well, it really all depends on your idea of normal...
Old Dec 16, 2008 | 01:12 PM
cannuck's Avatar
as in traffic
