H/P Tuners and the SS
What is your serial number eric? I have an update that adds HHR SS 2.0t support.
William Henn
HP Tuners LLC.
www.hptuners.com
It's official H/P Tuners is now supporting the HHR/SS and the tune will be going into my HHR on the 11th...Bill is saying roughly 30 extra horses just from the tune and this is just the beta version...More to come
Thanks Bill
William Henn
HP Tuners LLC.
www.hptuners.com
Have someone hook up the H/P Tuners computer tuning software to it and reflash the ECM....www.hptuners.com to buy it yourself its roughly $700 to tune it 1/2 the price...
William Henn
HP Tuners LLC.
www.hptuners.com
Thanks Bill
William Henn
HP Tuners LLC.
www.hptuners.com
You've got to be able to know a tuner in your area..I know of 4 here in Houston area 3 of them do mail order tunes but then you'd be W/O a vehicle for a couple of days.....Wheatley tuning,Nelson Tuning, And T3 Tuning is the one im going to use....
Just popped the email over to support with my log, hopefully I can have a new version by the weekend and can toss it on the dyno Sat :)
I dont need to know a tuner, just a version that can write the pcm, right now the currentl version cant support the hhr, it reads it as a solstice and cannot modify the stock base tune because of that.
We have posted an update on your customer login page located at www.hptuners.com
This update adds support for the 08' HHR SS 2.0t for which you previously contacted support
Please Download & install this new version at your earliest convenience.
If you run into an issue while using this beta version please make support@hptuners.com your first point of contact.
William Henn
HP Tuners LLC.
www.hptuners.com
versions of 2.1 beta are the same. The versions dated after 2/29/08
WILL WRITE to the pcm as well as reading them. If you plan to try and increase boost, you can't do it with HPT yet. You can change PE's to
richen things up but u have to do others mods to increase boost. There
is a wgate mod but it tends to get unlearned. Taking boost control away
from the ecm is the only way so far to get an increased and flat boost
curve until HPT supports that idea of the code.
turbofreak
