HHR SS Fuel Pressure
Old Feb 10, 2018 | 03:46 PM
drspock's Avatar
Ok im still confused about what the fuel pressure should be. I installed a Walbro 255 pump and the can absolutely runs great! Of coarse i also installed a K&
N High Flow X-Steam Air filter at the same time so maybe the combination, it really takes off quick now and boost to 20+ lbs fast. However, the fuel pressure gauge on my dash says 50 lbs solid above idle, sometime 53, but never 60 or 70 as some on here state. I also changed the fuel regulator sensor. I will double check by checking the pressure with another gauge at the tap in the front. May the person having 70 it is due to a program?. I would like an accurate OEM pressure spec if anyone knows it.
Old Feb 10, 2018 | 07:40 PM
Old Feb 11, 2018 | 09:24 AM
2005HHRauto's Avatar
KOEO (key-on-engine-off)
Should be at least 50psi
If your buggy isn't throwing any 'codes', & it's running great, your a-ok...
Don't even think about 'tapping' the high-pressure side, as your asking for trouble, or even death...
https://forum.hptuners.com/showthrea...-Fuel-Pressure
Old Feb 11, 2018 | 09:59 AM
I guess the "book" is wrong then.
Old Feb 11, 2018 | 10:55 AM
Is it possible that the book is in reference to the fuel pump for the 2.2, 2.4 in tank fuel pump, and not the HPFP of the SS?
Old Feb 11, 2018 | 11:39 AM
No, that's why I included the special instructions for disconnecting the HPFP line. See step 2(1) in the green hilite.
The "book" has been wrong before.
Old Feb 11, 2018 | 11:44 AM
Ok, just checking. My fuel pump had 55 PSI on the 2.2 but I don’t know what the i tank pump has for the SS.
Most listings could be generic like the ball joint fiasco
drspock
Feb 1, 2018 07:41 PM
Michael Benedict
Aug 20, 2016 11:07 AM
bartSS
Jan 20, 2010 01:25 PM
esmarkey
May 3, 2009 12:50 PM
graydog
Jan 9, 2009 05:23 PM
