HID question
Old Feb 5, 2012 | 11:07 PM
moonsign's Avatar
HID question
Just installed Depo headlight, and 6000k HID Hi-Lo beam lights.
Everything seems to be working fine, except that I don't have daytime running lights now.
Also Left side HID lamp seems to flicker once in awhile. Noticeable when close to walls or garage door. "Moon"
Old Feb 5, 2012 | 11:36 PM
prod's Avatar
With hids you should disable the DRLs by pulling the fuse.
Otherwise it tries to run them at half power, which could actually damage them. This should be in the instructions.
Old Feb 5, 2012 | 11:44 PM
moonsign's Avatar
I was a little PO'ed, as there was no instructions on them. I used the diagram on the ballast's to figure out how to hook them up.
So I should pull the Fuse to the DRL's, Right?
Anything else I should know, about these HID's[other than they are probably the cheap seats]? Thanks "Moon"
Old Feb 6, 2012 | 12:35 PM
prod's Avatar
I havent pulled my own fuse, but from what I hear on this forum it works fine to deactivate the feature. You might want to search for that thread.
Yeah youre SS has the headlights running the high beams at half power for the daytime running lights. 2006 HHRs with the amber DRLs wouldnt have an issue.
Half power may not be enough to ignite the HID bulb. It may not work, or may flicker, or it could wear out the ballast trying to get an arc.
If you pull the DRL fuse and they still dont work properly, make sure you contact the seller. With cheaper HID kits, many people have problems. One reason I dont have them.
Old Feb 6, 2012 | 10:59 PM
peevlos's Avatar
fuse #31
Old Feb 7, 2012 | 12:21 PM
Chevy13's Avatar
I would like to turn my yellow lights into DRLs but I haven't tried yet. That's what I plan on doing when I install my HIDs. Probably a jumper wire in the fuse box
Old Feb 10, 2012 | 10:49 AM
sanmn420's Avatar
Hey Moon, what HIDs did u go with? I been looking at the DDMs and the Xentecs on Ebay.
Old Feb 10, 2012 | 05:51 PM
moonsign's Avatar
sanmn420: I went with the 6000k HID's that come as a kit with the Depo headlights. Got them off of E-bay [street scene]. "Moon"
Old Feb 11, 2012 | 09:02 AM
sanmn420's Avatar
Thanks. I'll be ordering some soon.
betterof2evils4
Apr 3, 2017 08:34 AM
FargoFlash
Jul 12, 2011 04:54 PM
