How do you manually turn with an automatic?
Old Feb 12, 2016 | 10:21 AM
I'm working on another how-to, this time for shell blasting the intake valves. I realized I don't know how to turn the rotating assembly manually, if equipped with an automatic transmission. Do you really have to pull the timing cover and turn the crankshaft with a socket on the bolt? Does the valve cover have to come off, too?
Thanks, whoever submits the winning answer will be credited in the how to!! Think of the accolades!! The honor and respect that come with being mentioned in such a prestigious publication!!
Old Feb 12, 2016 | 10:33 AM
The harmonic balancer has a bolt head. NEVER turn the engine backwards.
An automatic is always in neutral. Torque converter need RPMs to engage.
aradmahogany's Avatar
Don't know about this car but with another automatic vehicle while doing the timing I still had to turn the engine with a socket... I think all engines you would be doing that.
Old Feb 12, 2016 | 10:34 AM
What don said :P
Old Feb 12, 2016 | 11:06 AM
Turn the engine clockwise by the harmonic balancer bolt, it's a lot easier with the spark plugs removed
You should not have to remove the front engine or the valve covers
Old Feb 12, 2016 | 11:07 AM
Thanks Donbrew. So you'd stand on the passenger side and turn it.... clockwise?
Old Feb 12, 2016 | 11:08 AM
Thanks, OB!
Old Feb 12, 2016 | 11:10 AM
I'd have to kneel on the passenger side as I don't have a lift or hoist!
Old Feb 12, 2016 | 02:03 PM
Well I have to take it off the jackstands when I need to work in the engine bay!
Farmers Daughter
Mar 31, 2014 06:09 PM
eagle914
Jan 15, 2013 11:10 AM
Q-Dog
Dec 22, 2010 05:43 AM
corvairman
Feb 12, 2010 07:36 PM
itschaboykenny
Jun 13, 2008 07:43 AM
