I'm Truly Impressed
Old Jun 11, 2023 | 12:33 AM
ibenzawla's Avatar
Little Update
Thanks for all responses. Just a little update. I have been using premium gas from mostly cheap gas stations for a year or so. Recently I decided to switch to the more expensive top tier gas stations and i'm noticing better performance and MPG. With the cheap gas I used to hear some slight engine rattles once a while but it now runs pretty smooth since switching. Won't be using cheap gas anymore unless its the only one available. Also I have removed the Pedal Commander. I think throttle response is better with it as advertised but I feel like its confusing the engine ECM. A bit too jumpy. Also think that the "Competitive Mode" feature works better without it.
Old Jun 14, 2023 | 06:56 AM
PulpFriction's Avatar
After a little injector cleaner in the fuel, I have had similar positive results buying only to "Top Tier" fuel. GM recommends it.
Old Jun 29, 2023 | 11:06 PM
ibenzawla's Avatar
Yes it makes perfect sense. Will mostly be using top tier.
WilliamKirkland
Jun 20, 2021 07:11 AM
hardwaremack
Apr 12, 2017 01:51 AM
Hib Halverson
Maintenance and Upkeep
20
May 9, 2015 11:59 AM
boanerges1
Jun 11, 2014 01:46 PM
wowjason
Jan 21, 2014 09:33 PM
