Joining the family :)
Old Jan 27, 2014 | 12:31 PM
  #71
sinabu's Avatar
A friend here at a Bluetooth OBDII scanner. We ran a system check just to see and it didnt get any codes etc which I figured.
Someone else suggested plugging/unplugging a connector on the passenger side kick panel and pulling the negative terminal for 15 minutes. Will try that tonight when I get home from work to see if that clears and then reintroduce the camera to see if it appears
Old Jan 27, 2014 | 04:47 PM
  #72
sinabu's Avatar
Got home and unhooked the negative battery terminal and let that sit about 15 minutes. Checked the connectors under the seats and in the passenger side kick panel and so far the light did not return. Hooked the dash cam back up and still no code when I idled it for a few minutes. Hopefully just a fluke from installing the camera.
Old Jan 27, 2014 | 05:14 PM
  #73
sinabu's Avatar
Oh forgot to mention while resetting the ss I noticed the vent tube on the battery was broken. I've ordered up a replacement.
Old Jan 28, 2014 | 09:10 PM
  #74
sinabu's Avatar
Getting Snow tonight First time in about 3-4 years
Old Feb 16, 2014 | 01:08 PM
  #75
sinabu's Avatar
Got the rear billet emblem in and put on today. Also replaced the broken battery vent cable.
Old Feb 20, 2014 | 03:15 PM
  #76
sinabu's Avatar
Just ordered up a Forge BPV, New KYB Rear shocks along with new sway bar bushings and end links
Need to save up for the Lowering Springs and Front Struts now and maybe a few more things before getting to work
Old Feb 20, 2014 | 08:50 PM
  #77
fiveothis's Avatar
Where did you buy the forge BPV
Old Feb 21, 2014 | 05:33 AM
  #78
eaglefreak138's Avatar
https://badnewsracing.3dcartstores.com/mobile/#page-103
Old Feb 21, 2014 | 09:27 AM
  #79
sinabu's Avatar
I got mine from Genuine Saab, There $25 cheaper than BNR
http://www.genuinesaab.com/catalog/p...roducts_id=827
Old Feb 21, 2014 | 01:05 PM
  #80
sinabu's Avatar
Any recommendations on Front Struts? From Searching around I don't see very many options other than OEM.
This is what I'm looking at now
Struts
ACDELCO Part # 506667 More Info {#19179738} OES
ACDELCO Part # 560581 More Info {#19179741, 20794824} OES
Bellow
MOOG Part # K90460 More Info Incl. Bumper Front x2
SACHS Part # 802479 More Info Strut Mount and Bearing x2
ACDELCO Part # 11569856 {#22716359} OES
NUT,FRT SUSP STRUT x2
