ss dash gauge
Old 01-26-2018, 06:15 PM
Chet043's Avatar
ss dash gauge
Does anyone know where I can get one of those stand up turbo displays that goes on top of the dash in the cubby?
Chet043 is offline
Old 01-26-2018, 07:16 PM
celblazer's Avatar
RPD is what you are looking for, check Ebay, dealers and junkyards. After 2009 it should just plug in. 2008 may not be wired if my memory is correct.
celblazer is offline
Old 01-26-2018, 07:17 PM
Chet043's Avatar
09
thank you it is for a 09
Chet043 is offline
Old 01-26-2018, 10:42 PM
Reconfigurable Performance Display (RPD)
And it's much more than just a boost gauge.
Since all 2010 SS's had the RPD, that would be the year to search for when looking in a wrecking yard.
firemangeorge is offline
Old 02-11-2018, 11:14 AM
Chet043's Avatar
Need
I am definitely looking for one of those RPD’s now. Got a ss panel in my driveway any help would be greatly appreciated
Chet043 is offline
Old 02-11-2018, 11:43 AM
Technical Moderator
I am not sure about the "just plug in" on a 2009. I have read that unplugging the RPD will cause the engine to not run, it is part of the CAN bus.
Maybe, I have been misled.
donbrew is offline
Old 02-11-2018, 08:13 PM
Chet043's Avatar
info
I was reading some where that on a 09 ss the rpd was a option so under the cubby was the rpd plug with a jumper wire installed. So unplug the jumper and plug in the rpd and it would work
Chet043 is offline
Old 03-20-2018, 06:34 AM
Chet043's Avatar
Rpd
Still haven’t found one anyone had any luck?
Chet043 is offline
Old 03-20-2018, 07:01 PM
Go to a local reputable wrecking yard and let them locate one for you. The better yards have the online system that lets them locate specific models across the U.S.
Somewhere there is a wrecked SS in a yard with the RPD. Just might have to talk your local guy into going the extra mile to find one.
Old 04-17-2018, 10:56 AM
DON'S HHR SS's Avatar
Reconfigurable performance display ( rpd ) for ’09 -'10 chevy hhr ss
I'm not sure if you found what you are looking for but there is a current listing for the RPD. on Ebay. The listing name is 'RECONFIGURABLE PERFORMANCE DISPLAY ( RPD ) FOR ’09 -'10 CHEVY HHR SS' . I was looking for the part number for the plastic insert that goes under the display when I came across it today.
DON'S HHR SS is offline
Quick Reply: ss dash gauge
