MANUAL or AUTO ..UPGRADE VOIDS
Old Dec 17, 2008 | 04:27 AM
tony326's Avatar
i need feedback manual or auto lets hear the pros and cons,
i read stories of auto cant handle the power and failing, clutch failures with 5sp,
as more horsepower is reach where is the weak link,trans,shafts,clutch or driver
what is good about the automatics compare to manuals with the turbo,
manual with posi looks like the best choice for autocrossing,
auto for drag racing and the wife to get around town and city driving.
no arm rest with the manual, maybe i can add a shorty arm rest for long trips
i believe drive train will be cover under 100,000 warranty, so does it really matter if they fail,
has anyone here been denied and been told the upgrades voided the warranty on their new car?
Old Dec 17, 2008 | 05:00 AM
Jeff®'s Avatar
If you're asking about the GM stage kit, it is fully warrented. As for the MX vs AX, both end up with the same HP and torque. There's a couple other threads around here. Check the 2.0 performance board.
Old Dec 17, 2008 | 05:47 AM
longhornss's Avatar
Love my 5 Speed would not traid it for anything, thinking about the 09 stage when it comes out. Also if you look in the threads you can find a how to and part list to install a factory armrest.
Old Dec 17, 2008 | 08:49 AM
ChevyMgr's Avatar
Clutch disc and pressure plate are not covered by GM powertrain warranty.
Old Dec 17, 2008 | 08:53 AM
esmarkey's Avatar
One thing that may help your decision is that you can only get the Limited Slip Differential (LSD) in the manual transmission.
Old Dec 17, 2008 | 10:17 AM
rommer's Avatar
Which was one of the key must haves for me. I live in the hilly area of North Jersey and have always had 4 wheel drive. I don't expect my SS to ever be 4 wheel drive like but 2 wheels driving are still better than 1!
Old Dec 17, 2008 | 10:30 AM
tony326's Avatar
clutch failure (parts failure) or auto trans slipping or no shift (burnt disc)or broken parts including axle shafts would be cover under warranty????
Old Dec 17, 2008 | 10:47 AM
bartSS's Avatar
everything except for the clutch and the pressure plate is covered
Old Dec 17, 2008 | 11:01 AM
ChevyMgr's Avatar
clutch failure (parts failure)yes or auto trans slipping yes if it's a defect
or no shift (burnt disc) no
or broken parts including axle shafts broken? only covered if not abuse or physical damage. (not a common failure though)
Answers are in bold.
Old Dec 17, 2008 | 12:32 PM
esmarkey's Avatar
Here is why I think the LSD is important (out of GMs info on the Manual):
"A limited-slip differential is available for high-output applications. This torque-sensing differential is an all-mechanical geared unit that uses no clutch packs or preloading to transfer torque from one axle to the other, and torque transfer occurs automatically when one wheel loses traction. Torque transfer also occurs gradually, without steps."
This not just a clutch pack.
