Is it me or does Comp and ESC off mode change the boost regulation
Old Feb 6, 2010 | 09:06 PM
terryk's Avatar
I wouldn't expect the dyno numbers to be any different since you are going to wide open throttle during the run and in any of the modes you have max boost at WOT.
Where I see the difference is at part throttle. Now if the number were different...........
Old Feb 8, 2010 | 09:23 AM
foolmoon_design's Avatar
I don't know if thats entirely true, if there is any differance it would show on the graph for sure, as a different curve.
Old Feb 8, 2010 | 07:48 PM
87silver's Avatar
Geez, and I thought the comp mode was just like an "elevator door close" button. I swear it has an effect, but wondered if it was related to physics or psychology
Old Feb 9, 2010 | 07:56 PM
IgottaWoody's Avatar
Mental....like that muffler thats a few tones louder but actually does nothing...
"I" doesn't hold back per say...while it normally powers up in a controlled manner, I goes balls to the wall.......when you punch it, its gone...otherwise it just spools up.
Old Feb 10, 2010 | 10:33 PM
acolddark0's Avatar
A dyno graph wont be able to tell you much if its just a slight difference in the curve. If you dyno your car 5 times you most likely wont get the same curve anyway due to heat, airflow, etc. It'd be hard cause of all the different variables. I personally tried it on the street and didnt notice a difference. May be the placebo effect. Try with traction on, traction off, and comp mode. Traction control could be why you feel the difference. Its not killing the motor.
jmm121783
33
Mar 8, 2012 12:45 AM
gmdealerguy
Oct 19, 2011 08:53 AM
Razz2o4
Aug 12, 2008 02:52 PM
crazysteve
Apr 23, 2008 07:27 AM
c2vette
Jan 25, 2008 12:55 PM
