Moulded Spash Guards Specific to SS Models
Old Jun 3, 2009 | 07:13 PM
87silver's Avatar
I have seen listings for moulded splash guards for the HHR from many vendors including GM Parts Direct, but with the unique facias that are equipped with the SS models, I am reluctanct to order them, since they are vague in their applications in this area. I would have to think that the facias may be different between the LT/LS models and the SS'.
Would anyone know if moulded splash guards are available for the SS and where they can be purchased?
Thx
Old Jun 3, 2009 | 08:46 PM
hyperv6's Avatar
None are made or avaiable and and the GM ones will fit with only some minor triming on the front and the rears will bolt up with new holes drilled in the guard.
With so few SS around it is not a very good chance any will ever be made.
Do not be affraid of the factory ones and the effort it takes to install them. I was reluctant at first but after I put them on I felt silly for how easy it was to make them work.
Use a little black silicone between the fender and flap to kind of seal out the stones and dirt. Also this will firm up the mounting even more than the factory mounting. I would do this even on the regular HHR.
I used silicone on my molded guards on my GMC Sonoma. it worked very well and protected the body from them rubbing the paint.
Old Jun 3, 2009 | 09:31 PM
tomw's Avatar
My SS with Factory Mud Guards
Old Jun 4, 2009 | 06:07 AM
hyperv6's Avatar
Note the fronts need only a little trimming on lower side of the ground FX. Mostly where it rolls out. It trims with a sharp knife.
Last edited by HillsdaleHHR; Jun 4, 2009 at 06:15 AM. Reason: Removed pics from quote
Old Jun 4, 2009 | 10:43 AM
tomw's Avatar
Note,
I trimmed mine to fit the factory holes I did not drill new holes
Old Jun 4, 2009 | 10:45 AM
DMarotta's Avatar
Tom,
Didnt I see your car for sale within the last month?
Last edited by DMarotta; Jun 4, 2009 at 10:45 AM. Reason: left out who I was talking to
Old Jun 4, 2009 | 11:51 AM
Mr.Redface's Avatar
Bought the guards at the Dealer and for $74 dollars they trimmed and installed.
Old Jun 4, 2009 | 11:57 AM
hyperv6's Avatar
Note,
I used the factory holes in front but the back were level and dropped the guard a little lower. I liked how they set to I just put in the extra two holes.
I also used the bottom screw hole to male a solid mount. I used a small clamp I fabed up to make it firmly mounted.
Old Jun 4, 2009 | 05:38 PM
tomw's Avatar
Originally Posted by DMarotta
Tom,
Yes
My car is presently For Sale
HHR_style
"How To" Tutorial Library
34
Oct 30, 2013 03:58 PM
Condition1
Jun 29, 2010 04:29 PM
Olskool
17
Jul 5, 2007 05:20 PM
