Need help. SS front rotors
Old Apr 18, 2013 | 09:08 PM
foxtrotraptor's Avatar
So I'm gonna need new front rotors. I need your help guys and gals. What rotors work well? I'm looking for something that last longer and better stopping potential. Should I go for slotted or cross drilled and slotted?
Old Apr 18, 2013 | 09:16 PM
Or dimpled and slotted....
Get some of these you won't believe how they stop.
Old Apr 18, 2013 | 10:10 PM
Those brembos are nice but unfortunately my wallet can't accommodate that :/.
Old Apr 18, 2013 | 10:35 PM
These guy's make nice stuff, you can find the std SS size. I think they are down by you. American made.
http://brakeperformance.com/brake-ro...ake-Rotors.php
Old Apr 18, 2013 | 10:53 PM
Cool thanks that's a big help but what's the difference between dimpled and slotted and cross drilled and slotted? the pictures look the same for both.
Old Apr 19, 2013 | 02:02 AM
prod's Avatar
drilled - holes right through to the other side
dimpled - just the tip of the drill makes a "dent" in the surface
some drilled rotors have been known to crack, while im sure most are fine. Street cars dont benefit from drilled rotors IMO, race cars need the extra cooling.
Old Apr 19, 2013 | 02:46 AM
So dimpled would be ok for a street car? Or should i just do plain slotted
Old Apr 19, 2013 | 03:23 AM
prod's Avatar
I should be installing my slotted rotors in a couple weeks. Im hoping the increased scrub helps resist the common brake pulsation issue caused by pad material sticking to the rotors.
Old Apr 19, 2013 | 06:55 AM
solman98's Avatar
Please post the results.
Old Apr 19, 2013 | 03:23 PM
B.Diggity's Avatar
Same reason why i went with the drilled/slotted. Gettin em painted and so forth but shoulf have em installed in a month:)
