No crank
My car was recovered from being stolen unfortunately; it is no longer running.
*********ISUESSES ID*********** (Attempts in Resolving Issue) Observation
Checked all Fuses and Relays (+)
Has Gas
Has fuel and the starter has power.
HHR will not crank.
What does everyone this is the issue? Helpful comments welcomed and appreciated
- The key was broke of in the ignition. ( I removed the ignition lock cylinder making it easier to remove the broken key. After removing the broken key; the original ignition lock cylinder was reinstalled.) No security light. Intends on using original spear key.
- Shifting Leakage cable has been replaced
- Shifter Handle has been replaced
- Battery was drained completely useless. (Bought Brand New Battery)
- Check Engine Light ON ( scanned codes: PO496)
Has Gas
HHR will not crank.
HHR ? Year ? Model ? Auto or 5 speed ?.......................(So we know what we are commenting about)
So. What key are you trying to use ? Is it a transponder key that is programmed to the car ? Should have the little "+" symbol on it.
Quote :Shifting Leakage cable has been replaced (guess you meant Linkage here)
Why were these replaced ? Damage from the theft ? Those 2 parts require specific technical replacement for them to work correctly.
