Odd LCA/ball joint combo
Old Dec 13, 2023 | 08:27 PM
  #31
Years ago I got generic bushings from NAPA that were solid rubber. They were about $8 each. I assumed then that they were for SS. I didn't use them, got full LCAs instead.
Old Jan 10, 2024 | 12:27 PM
  #32
ecl's Avatar
ecl
I just recently replaced my lower control arms on my 09 SS and also ran into the the SS larger ball joint not fitting. I had to get another pair of of control arms with the smaller ball joints to get it back together. I was completely confused.
Old Jan 10, 2024 | 02:10 PM
  #33
fastsuv's Avatar
Unless somebody replaced the aluminum knuckles with non-SS ones (if that's even possible), the larger diameter (20.5mm) ball joints are the correct ones.
Putting the smaller diameter ball joints used on non-SS HHRs will eventually damage the knuckle and/or cause handling issues.
As hhoyt posted above in post #25, a previous owner may have used the smaller ball joints and just tightened down the split-bore bolt until it was tight. It was a lot of work for him to spread it out to the right bore again.
Steve
Old Jan 10, 2024 | 04:14 PM
  #34
Agree, the knuckles are likely crushed down to the smaller size, like the OP experienced.
BLKHHRSS
71
Nov 13, 2022 04:09 PM
PulpFriction
52
Sep 10, 2022 07:02 AM
fastsuv
Mar 11, 2022 08:50 AM
PulpFriction
Jul 9, 2020 05:49 AM
donbrew
Jul 17, 2013 08:29 PM
